Dipstick!!!????
its hard to see just look for the hole on the side of the block just above where the pan meets the block on drivers side toward the back of the motor you might need a good light source...just put the end of the dipstick in that hole and ensure its pushed in all the way it can be a pain in the rear you might need an adjustable wrench and a hammer place adj. wrench adjusted to pipe diameter above bevel in tube and strike it with a hammer until bevel is flush with flat block surface... i hope i did'nt confuse you and goodluck....
hey Guero make sure you read above again i revised it after you posted...
just make sure it goes all the way in right???? should i throw some gasket maker crap on it??? one more question, does it go on the outside or the inside of the headers?
