I finally got my 4cyl conversion to the chasis dyno today. Everything was changed on the car fuel lines, aftermarket pump etc. It is a built 306 11.1 compression, windsor jr cast iron heads, GT 40 intake, X cam, 24lbs injectors and calibrated maf, Shorty headers, no cats, flowmasters, accufab 75mm tb, stock computer. The car has a tremec 3550 and 4.10 gears. The car made 248 rwhp at 5100 rpm and 290 ftlbs. The timing was set a 16 degrees by mistake, I meant to be at 14. We backed it to 14, and it made less power, went back to 16, and then 17 and thats when the power peaked. Should I be happy with these numbers? The dyno guy said he will play with the fuel pressure and get an accurate a/f but its not gonna make a huge difference. The dyno was a land/sea dyno, which I think is simular to a superflo or a mustang dyno. Is there more room for more power here?
