  • SN95 V6 Mustang Tech
Disassembling Rearend
  • Thread starter Thread starter stlboarder
  • Start date Start date Jan 2, 2004
stlboarder
215
Arizona
Jan 2, 2004
  • Jan 2, 2004
I'm trying to disassemble a 7.5" rearend I have in the garage and I have a couple questions.
1st. I trying to look and I can't find the c-clip for my life... maybe because I was doing it last night and didn't have enough light. But I can swear there wasn't one.
2nd. The 2 main girdles (I guess) that hold the whole assembly in the rear. The bolts are not coming of. They are definatley on there... am I missing something? Any tricks or tips?
E
ezkartpro125
24
florida
Jan 2, 2004
  • Jan 2, 2004
those bolts should be torqued down, so use an impact wrench to get them off. btw, are you rebuilding this rearend? bcuz theres alot of real precise clearances and stuff that you need special tools to get correct or else the rear will fail real quick.
stlboarder
215
Arizona
Jan 2, 2004
  • Jan 2, 2004
I got the rearend for free and I'm cleaning it out. Making sure everything is ok. And then I'm gonna change the fluid.
E
ezkartpro125
24
florida
Jan 2, 2004
  • Jan 2, 2004
dude im just warning you, rearends are a real precise assembly, if u just pull everything out and then just slap it back in and dont know about setting the wear patten and backlash and all that other stuff, its gonna blow like real quick
stlboarder
215
Arizona
Jan 2, 2004
  • Jan 2, 2004
Thanks for the warning. I'm probably not going to end up using it. I dunno... this is basically to learn more about them.
I got the 4 bolts off BTW.
I first went to Sears and got the adapter so I could use the socket set on my cordless drill... yea the adapter snaped.
So I went to the trusty ole 12 foot breaker bar. They came out like butter.
Now I need to just know how to take the two axles out. I can't figure it out. I'm gonna see if I can find a chiltons book on it.
AP1995V6
547
Oxford, MS
Jan 3, 2004
  • Jan 3, 2004
like totally d00d
marvinmycat
1,179
Buffalo, NY
Jan 4, 2004
  • Jan 4, 2004
I can't get the pic to upload as it is a bmp file and I'm at work. So follow this link and go to the following categories to get to the c-clip pic.
http://e-toolbox.com/ads/rq.cfm
Drive Train
Rear Axle
Rear Axle Shaft, Bearing and Seal
stlboarder
215
Arizona
Jan 4, 2004
  • Jan 4, 2004
What link?
marvinmycat
1,179
Buffalo, NY
Jan 4, 2004
  • Jan 4, 2004
http://e-toolbox.com/ads/index.cfm
H
HoofBeatsRfastr
40
Tulsa,OK
Jan 5, 2004
#10
  • Jan 5, 2004
  • #10
hey stlboarder, what year is your car, b/c I have the chilton's book for 94-98
stlboarder
215
Arizona
Jan 6, 2004
#11
  • Jan 6, 2004
  • #11
Thanks man!... that website is sweet. It solved my problem.
stlboarder
215
Arizona
Jan 6, 2004
#12
  • Jan 6, 2004
  • #12
My car is a '95 but the rearend I have is from a foxbody. Which I have a chilton's book for. Thanks anyway.
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Jul 14, 2026
joeybuddy96
J
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
M
  • mnky99
  • Sep 5, 2025
mnky99
M
