  • SN95 4.6L Mustang Tech
Disaster struck yesterday....
  • Thread starter Thread starter gotchopsticks
  • Start date Start date Jun 6, 2007
First Prev 2 of 2
Bluffing024
Somewhere
Jun 7, 2007
#21
  • Jun 7, 2007
  • #21
So is there a class action law suit?
Seems like a bigger problem than the intake manifold.
the98stang
2,408
Clovis, CA
Jun 8, 2007
#22
  • Jun 8, 2007
  • #22
Lawsuit? Ford states there is no "problem"
G
gotchopsticks
315
#23
  • Jun 8, 2007
  • #23
when i did the plugs, bosch single platinum, i torqued them to 32lbs i think (whatever you guys said on here) and it was a freshly calibrated wrench from autozone, and then a week later i retorqued them. the stock plugs had ~45k on them, and these have ~5k on them. i talked to a mechanic shop today in corona, CA, called Bob's Auto, and he said he can put in a new "sleve" with a reemer kit that taps right into the stock head, without removing the head, for a TOTAL of $300.00, and i will never have to worry about the plug again. he was telling me that this is a kit the dealer doesnt want anyone to kno about, and he has done it on many ford trucks and mustangs. should i try this and if it doesnt work then go aftermarket??? thanks for all the help so far...stangnet FTW!!
G
gotchopsticks
315
#24
  • Jun 8, 2007
  • #24
i'll be a supporter of a lawsuit if anyone wants to get one started
Bluffing024
Somewhere
Jun 8, 2007
#25
  • Jun 8, 2007
  • #25
He is probably using the Timesert kit. You are supposed to torque them to 13 ft lbs exactly. But the guy that runs http://www.blownoutsparkplug.com/ says in his FAQ that he torques them 28-32 ft lbs. I e-mailed him with this:
"I just wanted to let you know that in your FAQ it says you torque plugs to 28-32 lbs. I don't know about other motors, but the 96-04 Mustangs need torqued to EXACTLY 13 ft lbs."
He replied:
"If you feel this is ok @ 13 lbs then ok, I have fixed over 300 plugs and I found that a lose plug that wiggles in the hole causes the frailer. At 32 lbs it stays tight and does not strip and comes back out with no problem the next time. I tested the head threads and found that a good set of threads will handle over 100 lbs and not strip. I feel that 32 is the magic number and untill I find a failer I will continue with this #. So far 10 years and no call backs?????? Have a great day. If you have any more questions please call or email. Ric"
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 8, 2007
#26
  • Jun 8, 2007
  • #26
32lbs seems like way too much I will stick with 13.
Bluffing024
Somewhere
Jun 8, 2007
#27
  • Jun 8, 2007
  • #27
Kinda what I thought too. I thought I would post it up and see what people thought though.
LI98GTStang
1,715
L.I., NY
Jun 8, 2007
#28
  • Jun 8, 2007
  • #28
Sounds like the shop you are dealing with is on top of this issue for you.
I'm afraid to replace my stock plugs because of this issue. Not that I want or trust them, but I'm wondering if I take it to a stealership to replace the plugs, will they "warranty" their work against it rejecting since there isn't a problem?
svtpower
257
Wisconsin
Jun 8, 2007
#29
  • Jun 8, 2007
  • #29
nope
No, the stealership will not warranty the work against this type of problem. There is atleast one thread on Stangnet somewhere a guy had a Ford dealership change his plugs, one blew out later and they would not cover it.
I think the most important parts about changing your plugs on a stang are
1) Change them with a COLD engine.
2) use a small amount of anti-seize
3) use a torque wrench and torque them to spec (don't guess)
4) recheck the tightness every few thousand miles or so.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jun 8, 2007
#30
  • Jun 8, 2007
  • #30
the98stang said:
X 1,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000
I will work on a thread this weekend that we can sticky
G
gotchopsticks
315
#31
  • Jun 9, 2007
  • #31
maybe it was 13 lbs, it was what ever you guys said to do on here. i was in the shop the other day talking to the guy and he said it was 32 though....
40thmustanggt
34
#32
  • Jun 9, 2007
  • #32
whats a good set of after market heads?? and what would be the hp and tq gains?
4.6andSlicks
171
Central Connecticut
Jun 9, 2007
#33
  • Jun 9, 2007
  • #33
I agree except for #2. Skip the anti-sieze. I think that's 1/2 the problem with blowing plug out of the hole. Plugs already have an anti-corrosive finish on the threads. I just change the plugs every year with a good copper replacement NGK TR6's. A stone cold engine is an absolute must.
First Prev 2 of 2
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Tuesday at 10:14 PM
DangStitches
D
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
  • Gulftown980x
  • Jul 29, 2026
squeak93
O
My rebirth, Hi from PA
  • onemore1987
  • Jun 28, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 29, 2026
onemore1987
O
