Disc brake conversion kits $999.99???
  • Thread starter Thread starter '69Mach1Chick
  • Start date Start date Aug 30, 2004
  • 3
First Prev 2 of 3 Next Last
'69Mach1Chick
There's no grass left to cut.
Apr 1, 2002
348
North Jersey
Sep 1, 2004
#21
  • Sep 1, 2004
  • #21
$1,025.00 stainlesssteelbrakes.com, now what is the diffenrence between those and the cheaper wildwood ones?
R
rebel65
363
SF Bay Area
Sep 1, 2004
#22
  • Sep 1, 2004
  • #22
well since you didnt post what kit..which might just help..the most i can say is that it's better. better parts, better stopping power, and fits under stock wheels. and it's..26 dollars more than what you originally posted
'69Mach1Chick
Apr 1, 2002
348
North Jersey
Sep 1, 2004
#23
  • Sep 1, 2004
  • #23
Wtf? Shopping for clothes and shoes is so much easier.
Most of the kits seem to be the same. I'm looking at Wildwood, The paddock, and the Stainless Steel ones. I'm looking for the right one for my car and don't know what i need. I'm guessing i need one that comes with a drop spindle???
dodgestang
1,360
Cecil County, MD
Sep 1, 2004
#24
  • Sep 1, 2004
  • #24
You keep talking about spindles? Why do you need spindles? Is this car originally a 6 cylinder car? And why would you need drop spindles?
Maybe a little more info would helpful
http://www.mustangsplus.com/Merchan...=MPFMP&Product_Code=04907&Category_Code=front
blascrw
191
Opelika, AL
Sep 1, 2004
#25
  • Sep 1, 2004
  • #25
a little clarification
I am by no means an expert....but here it goes....
1. If you see a kit listed that has 1.) a single piston caliper or 2.) lists that it comes with spindles...it is likely a granada based kit...cal-mustang selles one of these. Usually will not work with stock wheels.
2. Stainless steel brakes kit is a direct bolt on application, and usually can use stock wheels. It is a 4 piston design.
3. Wilwood is a bolt on application, and is custom. You will need at least 15" wheels and is a 4 piston design, and I have heard it widens the track, therefore reducing the size tire you can run.
4. Baer I know the least about, but suspossed to be about the best...is a bolt on application and you need 15" wheels. They have a handy clearance template if I recall correctly. It is also a 4 piston design.
5. Other - I have seen some other kits out there that are bolt on that use various calipers and spindles, even some that use GM calipers...
6. Straight Granada - requires swap spindles, single piston design requires 15" wheels. Can cause some strange alignment and geometry issues with some aftermarket suspension...global west, grab-a-trak, and the shelby drop, and negative wedge kits...
All in all the "easiest" is the SSBC.
There is the whole other argument of single piston vs. 4 piston calipers that let's just leave alone
I hope this helps...
This is all based on my days and days and days of research...again I am not an expert!
Ron
9
93blownaod
14
so cal.
Sep 1, 2004
#26
  • Sep 1, 2004
  • #26
The Baer system is set up with PBR 2-piston caliper, not a 4-piston design, and I recall right I have seen some articles where the 2-piston design out performed SSBC 4-piston design. You have to see what Caliper SSBC is using. Just remember Bigger is not always better. Baers SS system will fit a 15" wheel and some cases will also fit some 14" wheels.
blascrw
191
Opelika, AL
Sep 1, 2004
#27
  • Sep 1, 2004
  • #27
Thanks
thanks for the clarification...
I know the least about the baer system...
Like I said there is a whole another discussion about the pro's and con's of each systems caliper design 1, 2, 4 piston....
Any of these installed properly with a new dual resivoir master cylinder and adjustable proportionaing vale adjusted right will stop a whole heap of alot better than stock 4 wheel drum!
RajunCajun
180
#28
  • Sep 1, 2004
  • #28
I like my SSBC kit for my 66 top notch
'69Mach1Chick
Apr 1, 2002
348
North Jersey
Sep 1, 2004
#29
  • Sep 1, 2004
  • #29
So, if i have an original 8cyl, 5-lug car,with power brakes and they are 14"s, i can buy the ssb kit and i can bolt it on myself and be able to upgrade to larger ris in the future?. I have no idea how brakes work. I'm a body person i've yet to learn all the other stuff.
'69Mach1Chick
Apr 1, 2002
348
North Jersey
Sep 1, 2004
#30
  • Sep 1, 2004
  • #30
http://www.mustangsplus.com/Merchan...=MPFMP&Product_Code=06419&Category_Code=front
Dodgestang...i have a 69
blascrw
191
Opelika, AL
Sep 1, 2004
#31
  • Sep 1, 2004
  • #31
not quite...
The kit you have linked is the force 10 kit...that one requires 15" wheels as it has larger diameter rotors...
Ron
Billgear
500
Concord, CA
Sep 1, 2004
#32
  • Sep 1, 2004
  • #32
Baer has a couple kits that would work. The serious street kit they have uses 11" rotors and the 2 piston PBR calipers, this kit fits the 15" wheels. This kit is priced about what the SSBC kit is, maybe a bit less. The other kit is called the "track" kit. Used 13" rotors and the same PBR calipers. You have options of 2 piece rotors and you can also get the caliper in different colors.
The Baer track kit can be had for about what the SSBC kit cost, 2 piece rotors are available at an additional cost.
I had the SSBC kit and am upgrading to the Baer track kit for more stopping power on the track. For the street, eitther of the kits is great. Here is a couple pics of the Baer track kit, before install...
2 piece rotor and calipers
Another shot of the spiffy red calipers
mastercylinder from baer kit
side shot of rotors 13"x1.10
'69Mach1Chick
Apr 1, 2002
348
North Jersey
Sep 2, 2004
#33
  • Sep 2, 2004
  • #33
Someone please explain to me this whole piston thing. What is PBR?
dodgestang
1,360
Cecil County, MD
Sep 2, 2004
#34
  • Sep 2, 2004
  • #34
I used the wrong link.
Standard SSBC kits are $925 regardless of year:
http://www.mustangsplus.com/Merchan...=MPFMP&Product_Code=04815&Category_Code=front
blascrw
191
Opelika, AL
Sep 2, 2004
#35
  • Sep 2, 2004
  • #35
Please NOOOOOOO
Lets please not get into the whole argument on 1 vs 2 vs 4 piston braking systems...
Let's just leave that issue alone...
Like I said ANY of these systems properly installed and adjusted will be WAY WAY WAY better than stock drum.....
Just determin whether you need to keep your stock wheels or not...If you DO and they are 14" you basically have to stay with the SSBC brakes...
If not you are free to choose which every you like...
I think I PERSONALLY have descided to go with the Wilwood...eventhough I have not heard from anyone who has it.
Ron
blascrw
191
Opelika, AL
Sep 2, 2004
#36
  • Sep 2, 2004
  • #36
Wilwood...
In case anyone is interested....
Here is where I am looking at the Wilwood...
http://www.hotrodsusa.com/store/dpsfront_hub.html
Ron
blascrw
191
Opelika, AL
Sep 2, 2004
#37
  • Sep 2, 2004
  • #37
What to do what to do.....
Well thought I had descided of the Wilwoods...
Then I see what appears to be a SSBC kit from mustangsunlimited...
http://www.mustangsunlimited.com/itemdy00.asp?T1=A120D+01
for not too much more...then could keep my factory 69 GT wheels...
But then to add to the mix....A buddy came through...
a complete set of Granada Spindles, caliper mounts, calipers, rotors (still thick) for less than 200 shipped to me...
Hmmm
200 spindles
205 ALL new parts including reman calipers & new Rotors...
_____
405
405 Granada
651 Wilwoods
798 mustangsunlimited (SSBC???)
Descisions Descisions.....
blascrw
191
Opelika, AL
Sep 2, 2004
#38
  • Sep 2, 2004
  • #38
HMMMM
I guess I just keep on posting to this thread....
I spoke with Thamer at Mustangs Unlimited Atlanta warehouse...
This one: http://www.mustangsunlimited.com/itemdy00.asp?T1=A120D+01
IS a SSBC for $798.00 in stock!
Best price I have seen for a SSBC...
Ron
65fsbkhipo
1,296
Tampa, FL
Sep 2, 2004
#39
  • Sep 2, 2004
  • #39
[QUOTE='69Mach1Chick]Since all new drums would be the same price im thinking about front disc conversion. I found a kit including everything, even the spindles, for $999.99. Does this sound good? I have 5 lugs now so the company said it is just a bolt on and all the parts are new. Eventually can I change to a larger rim?[/QUOTE]
You may want to take a look at these before you buy. I put them on all my cars.
Disc Brakes Conversions
blascrw
191
Opelika, AL
Sep 2, 2004
#40
  • Sep 2, 2004
  • #40
Same kit
That is the same kit I linked to from Mustangs unlimited...even same part number....
798 mustangs unlimited
875 florida mustang
Ron
  • 3
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Manual disc brakes
  • Butchd88
  • Feb 28, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
zookeeper
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Rear Disc and Rims Offsets
  • TripleYellow
  • Nov 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 9, 2026
TripleYellow
