disc brake conversion problems-66FB
  • Thread starter Thread starter randy66gt350
  • Start date Start date Dec 6, 2004
R
randy66gt350
20+ Year Stangneter
Jan 11, 2003
47
utica, mi
Dec 6, 2004
  • Dec 6, 2004
I installed (mostly) a Stainless Steel Brakes, front disc conversion kit over the weekend. This is the stock replacement kit w/ mini booster and 67 style dual pot mc and was purchased solely because it's supposed to clear the stock 14" wheels (I have to run these in the class that I'll be racing in). When I put the wheels on (styled steel wheels, I'm assuming original to the car based on their condition..14x6???) , surprise, they hit the bottom of the caliper. Has anyone encountered this? I can turn the wheel by hand, but it's definitely hitting. How much meat can be removed from the caliper? I was so disgusted, I put my tools away and went in the house. Still need to install the booster, mc and dist. valve.
Snail50
787
Miami
Dec 6, 2004
  • Dec 6, 2004
I've heard of Baer kits hitting 16" wheels, which is why I had to go with 17"s on my 67.
If you can still mount the wheel and turn it by hand, then I'd imagine that you could remove enough metal from the calipers to give yourself clearance.
Is it making contact across the entire outside surface of the caliper, or only at a high spot, such as a corner?
Can you also use different wheels? You said you have to run "stock 14" wheels", but perhaps there are other "stock 14" wheels" for a Mustang which might give you better clearance, or at least have enough metal inside the wheel to machine some metal from the wheel, and also some from the caliper, giving you even more clearance than by removing it from the caliper alone.
degins
361
Texas
Dec 7, 2004
  • Dec 7, 2004
If your studs are long enough you can use a 3/16" wheel spacer. They are available on Ebay for about $15 shipped. This cleared my problem with 14" Magmun 500's on my 64 disc conversion. My wheels were also barely interfering at the caliper.
R
randy66gt350
20+ Year Stangneter
Jan 11, 2003
47
utica, mi
Dec 7, 2004
  • Dec 7, 2004
I can use any stock 66 wheel, but I don't want to invest $600 in a set of wheels that don't fit any better. I'm just hitting on one corner.
The spacer crossed my mind. How many threads have to stick through the wheel?
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Rear Disc and Rims Offsets
  • TripleYellow
  • Nov 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 9, 2026
TripleYellow
D
Brakes 1966 Mustang convertible 289, Auto - Disc brake conversion issues
  • DRGunn427
  • Feb 26, 2025
Classic Mustang Specific Tech Jul 23, 2026
All Stock93
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
