Hello Guys,
I will soon be bringing home a 1966 Factory 4V/4 Speed with (COLD) AC & Power Brakes. I have a question about doing a brake swap to power discs.
I know that 75-80 Granada/Monarch and 74+ Maverick/Comet front spindles, rotors, calipers, & proportioning valve will be a direct bolt on swap for the '66 Mustang. There are no local used parts from Mavericks or Granadas, however, one yard says that the later LTD II's such as the '84s are all the same as the Granadas, except for the 4 lug bolt pattern.
What I need to know is will the spindles of an LTDII interchange with the Granada, and if that is the case, since the LTD II is a Fox Body, will '89 Mustang spindles, rotors, and calipers interchange with the LTDII & Granada.
Any help you guys can provide will be greatly appreciated. As you know, the aftermarket kit to do this is close to $900. I can buy the LTDII parts for $80.00. Granted, I will probably have to buy new rotors and possibly new calipers, and definitely new bearings and hoses, but I think it would come in MUCH less than $900.
Now, let me add this.... I will soon be swapping out the spindles and brake parts on my '89 for '94-95 parts so I can fit the center pieces on the 17" 1998 Mustang wheels I have on it now. If the '89 Mustang parts are the same as the LTDII parts, and the LTDII is the same as the Granada, it looks like I will have everything I will need for the '66. Keep in mind, the '89 Mustang has already had 5 lug rotors and axles in place of the 4 lug originals.
I hope this isn't too long winded or confusing. It's almost as clear as mud for me.
Thanks,
Scott Fouts (Brand new member here)
Northwest Georgia, USA
'89 Mustang LX 5.0 - Saleen Twin
'66 Mustang A Code/4 Speed with AC & Power Brakes (arriving soon)
Thanks,
