  • SN95 4.6L Mustang Tech
Disk brake piston twist
  • Thread starter Thread starter 85MustGT
  • Start date Start date Apr 15, 2005
85MustGT
95
Occupied San Diego
Apr 15, 2005
  • Apr 15, 2005
How do you use the tool to compress the piston in a 4 wheel disk setup? Why does it twist to compress?
http://www.sears.com/sr/javasr/prod...vertical=TOOL&pid=00946344000&tab=des#tablink
slytherin
702
northeast ohio
Apr 15, 2005
  • Apr 15, 2005
You must be talking about rear disc brakes it has to do with the workings of the Ebrake, not sure how it works though. I used a pair of needle nose pliers to turn my rear pistons whatta pain. turn clockwise till fully compressed, take the cap off resevoir(sp) this helps relieve some of the pressure.
Acheron315
235
Charleston, SC
Apr 15, 2005
  • Apr 15, 2005
That is for the rear only. I bought a tool like that and it was not wide enough to work on the Ford rear caliper piston. I made my own out of some scrap metal and an old socket so I could use a ratchet to turn it in.
Best bet would be to check with a place like Ford or Advanced auto and see if they have one that will definitely work with the Ford caliper.
G
GT300HP
29
Silver Spring, Lanham, Owings Mills, MD and South
Apr 15, 2005
  • Apr 15, 2005
I just changed my brakes last weekend...I used a pair of channel locks and twisted it until it went all the way in.
YardSpecial
2,664
MT
Apr 15, 2005
  • Apr 15, 2005
I just spent the coin for the REAL tool for $40 and used that.
The only way to go.
Mac is the brand I have.
C
Conv99GT
93
Montague,Mass.
Apr 15, 2005
  • Apr 15, 2005
I bought a tool from caps it did not fit either just ground a little off the tool and it was good to go
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Apr 15, 2005
  • Apr 15, 2005
i use the Snap-On one and it works like a champ.
Drivetrain 33 spline SN axle with ABS and parking brake build
  • revhead347
  • May 12, 2020
  • 1994 - 1995 Specific Tech
4K
1994 - 1995 Specific Tech May 12, 2020
revhead347
Brakes 1979-1986 Fox Parking Brake Adjustment
  • LiquidStangs
  • Sep 22, 2019
10K
Fox 5.0 Mustang Tech Sep 23, 2019
LX Dave
Definitely not a new member (joined in 2005), but beyond searching I'll finally be posting:) New to me 1983 4-Eye Notch in my possession now:)
  • bahndrvr
  • Jan 31, 2019
  • The Welcome Wagon
4K
The Welcome Wagon Feb 8, 2019
Olivethefet
D
Brakes Low Brake Pedal After Service - Need Advice
  • Dennis M Wilson
  • Apr 6, 2017
6K
SN95 4.6L Mustang Tech Apr 8, 2017
Sluggie24
T
Fox No Boost And Stumped
  • TWEECD
  • Aug 12, 2017
  • 2 3 4
13K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2017
TWEECD
T
