Dist question
  • Thread starter Thread starter Mustang Pilot
  • Start date Start date Dec 17, 2003
M
Mustang Pilot
28
Etown PA
Dec 17, 2003
  • Dec 17, 2003
I am building a 1986 GT not exactly stock. I have a 347 stroker with carb. and I am using the Duraspark II ign. and distributor. I am not really up on Mustangs or Fords since I have not touched one since 1970 so things have changed. I know this is a roller motor (HO) and I just found it should have a steel distributor gear. My question, I have not pulled it out yet but does a 1985 Duraspark II OEM distributor have a cast or steel gear. I am changing all over to MSD but I wonder if the OEM is cast how many miles would one have to drive before damage is done? Would it damage the cam gear or the distributor gear or both? I am worried.
Thanks
Sacramento CA.
Jan 4, 2004
  • Jan 4, 2004
If its an H.O. it should be a steel gear due to the H.O. cam.Make sure its steel and not cast or the cam drive gear will eat the distirbutor gear and all the metal will end up in the motor.Check part numbers closely.Do a search here and the Carbed Mustang list for distributor gear.
Thanks
hllon4whls
BANNED
2,567
Covington
Jan 4, 2004
  • Jan 4, 2004
YUP. If the donor motor had a factory roller, it should have the right gear!
ashford
485
fargo ND
Jan 5, 2004
  • Jan 5, 2004
also the tfi dist. used a shorter oil pump shaft. the duraspark will catch about a 1/4 inch of it
M
Mustang Pilot
28
Etown PA
Jan 5, 2004
  • Jan 5, 2004
Thanks for the help but can I ask another ?
I knew I needed a steel gear because of the roller cam. I really wanted to know, if a cast iron dist gear was used, would it also hurt the cam dist drive gear? I know the dist gear will get eaten. I orignally installed an OEM reman Duraspart II dist. for a 1985 HO. It was supposed to have a steel gear so I never verified. I found after 500 miles that it has a cast gear. I checked and Advance Auto Parts did not have the dist I needed so the idiot at the counter gave me a dist for a truck 302. It had a cast gear. I guess he thought it looked the same so oh well. I do not want to yank the cam but I need to know if it could have damaged the cam because I am going back to Advance and make them eat all the repairs. Can anyone tell me if the cam would have been damaged too? I tried to look thru the dist hole but my less than perfect vision just can't get a good enough look.
Thanks
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
