distributer stuck
  • Thread starter Thread starter gingerbreadman
  • Start date Start date Jun 12, 2005
gingerbreadman
Only half-baked
5,358
Go ahead, call me cheaky
Jun 12, 2005
  • Jun 12, 2005
77 f250 351m. it aint bugging
what do I do?? how do i get it out?
-gbm-
G
grego37
576
Fresno CA
Jun 13, 2005
  • Jun 13, 2005
spray some liquid wrench, WD40, LPS or something around base where its stuck in the block, let it sit, then do it again.
Then give a few safe taps on the housing.
Loup-garou
337
New Orleans, LA
Jun 13, 2005
  • Jun 13, 2005
Have you tried grabbing it with an oil filter wrench?
yeloxr7
429
  • Jun 13, 2005
Use the SEARCH function.
This problem was addressed about a month ago.....
gingerbreadman
Only half-baked
5,358
Jun 13, 2005
  • Jun 13, 2005
The wd-40 worked,
I let it sit overnight with a pool of wd in the distributer valley and it pulled out like butter, I guess it wasnt badly stuck.
thanks guys
-gbm-
G
grego37
576
Fresno CA
Jun 13, 2005
  • Jun 13, 2005
glad to hear it worked.
Just dont use it as a cooking spray.
yeloxr7
429
  • Jun 13, 2005
Now when you put the distributor back in, use ani-seize on the distributor housing where it goes into the block, both on the upper part you can see and the part down inside.
gingerbreadman
Only half-baked
5,358
Jun 13, 2005
  • Jun 13, 2005
as are alot of problems, if everyone used the search function for everything this forum would be pretty slow and eventually die
-gbm-
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
J
Foxbody trans swap
  • jimendo20
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
KRUISR
K
collapsed or stuck "lifter" ?
  • kingcoy
  • Oct 23, 2025
2005 - 2014 S-197 Mustang -General/Talk- Oct 23, 2025
nickyb
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
L
Progress Thread 1977.5 Mustang 2 advice.
  • LittleBlueM2
  • Mar 20, 2025
1974 - 1978 Mustang II Talk & Tech Mar 22, 2025
extra_stout
