The conversation got side tracked before it even got started. At no point did the OP confirm that the new distributor was installed and the timing was set with a timing light. If anything, the original post suggests the opposite. When you put a new distributor in, you have to set the timing WITH A TIMING LIGHT. You are not going to Kentucky Windage your timing and get it right. So set the timing correctly, and then report back on whether or not the distributor is faulty.
I've had a Cardone rebuilt in my car for 15 years now, works fine. It was even rebuilt using a foxbody casting, which I had to cut to make it fit with my intake. Works fine. Luck of the draw on rebuilt parts.
Kurt
Kurt
out of it . Hell my ride to work now is 62 miles one way . I do have spare tools , blower belt and connectors with me though just incase I need to do something quick .
