distributor base
  • Thread starter Thread starter slow5.0gt
  • Start date Start date Sep 25, 2006
slow5.0gt
138
  • Sep 25, 2006
Does breaking the distributor base cause the problems I have now?
Because when I was reinstalling the PIP to get the shaft out i hit the bottom gear with a hammer since I didnt have a gear puller and *pinkk*! the base of the shaft popped off, one of my friends said that the little cup looking thing underneath the base should be attached to the base and not moving seperatly. See the third picture in the link below if im too vague or using the wrong terms.
Im hoping this could be it because I have tested everything else and they all work good or have been replaced with a new part (except the module), ignition coil replaced,new cap and rotor, new stator, starter solenoid works I get spark to the plugs now but still no start fuel guage shows pressure new pump. Im just out of options
http://www.turbotbird.com/techinfo/TFI-PIP/TFI-PIP.htm
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
  • dan50
  • Jul 18, 2026
dan50
P
Engine Swapping EFI distributor for carb distributor- shaft length is different
  • pindude80
  • Jul 20, 2024
Fox 5.0 Mustang Tech Jul 21, 2024
pindude80
P
