Distributor cap wobble
ARTTII
272
Detroit, MI
I have a 93 lx 5.0 - the distributor cap seems to wobble around and not sit flat, am I missing something??
I have a remanufactured distributor, new cap and rotor, but original adapter. Should I try replacing the adapter? If so is that something I can pick up at autozone or Napa?
Thanks
It doesnt wobble while the car idles, right? It's just that you can put your hand on the cap and move it around a little?
If so, mine do that too. I dont know why the cap isnt located with screws (a la GM, etc) or at least locating pins (if they wanted to keep the straps that are used now).
Good luck.
If the cap has been removed often the spring tension clips can get a little loose and create some slop. Because of the clip design you'll be able to move the cap around, but you shouldn't be able to without at least a little bit of force.
The cap base with billet aluminum screw hold down clamps made for the 95 Cobra 'R' is available from PPI for $35.
Good luck.
Yea, only when you put your hand on it (I think, hope it is not moving while the engine idles)
What a cheap design... OK thanks for the info
