Distributor + electrical question
  • Thread starter Thread starter coolguy88
  • Start date Start date Jan 15, 2004
C
coolguy88
104
Poway, California
Jan 15, 2004
  • Jan 15, 2004
Hi guys, I currently have a stock dist with a petronix and msd 6a box. I would like to know if there would be a difference between this setup compared to a new billet msd dist.(the pin that holds the gear on my stock dist broke while I was on the freeway)
Another question, when I have my cd player on, it seems to be fighting for power with the msd box, strange things happen like backfire after acceleration, any idea how to remedy this?
6Stang7
1,470
Livermore, CA
Jan 16, 2004
  • Jan 16, 2004
Well, the bullet MSD distributor would be better of course, but would you need it? Probably not. As for the cd player power problems, I would check first to see where it is drawing power off of. It might be taking it from the coil/6a box, and therefore cause a power lose to either one which would result in running problems.
-Shaun
G
geegee
2,015
near Oklahoma City, OK
Jan 16, 2004
  • Jan 16, 2004
MSD produces a mean spark and your dinky distributor cap and rotor can't handle it. Thats why the later Duraspark ignition has that big round cap. If you can find a high voltage cap and rotor for your old Ford distributor then use it. If not, you'll need to use a Duraspark distributor or the MSD.
To check to see if you have any battery/alternator stability problems, test drive the car/engine with the stereo and any amplifier turned off. If the problem goes away with the stereo off but comes back with it on, then you have an alternator/battery stability problem.
G
GaPonyFarm
663
Columbus, GA
Jan 16, 2004
  • Jan 16, 2004
You'll certainly gain from using the MSD distributor...and coil.
What you really need to do is upgrade your alternator to something closer to 100 amps. The 61 amp unit only produces about 40 amps at lower speeds and it barely keeps up with stock configurations, much less ANY electrical add-ons. Your brake lights will be the first improvements and the folks following you will thank you. Make sure your CD player is not wired into the ignition circuit.
67efivert
348
lincolnton nc
Jan 16, 2004
  • Jan 16, 2004
i had a similar prob with my coupe my fan,ign,headlights, and blower motor drew more than my alt put out on the highway (not to mention idle)i ended up using a 75 amp late model alt with int regulator and no more problems
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
Fox Possible timing not sure
  • K1tha1
  • Apr 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2025
AeroCoupe
  • Locked
Engine Help timing possibly
  • K1tha1
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
