Distributor Install question
  • Thread starter Thread starter andrewb_80
  • Start date Start date Mar 20, 2010
andrewb_80
38
Dayton, Oh
Mar 20, 2010
  • Mar 20, 2010
I am changing over my prform HEI ignition system to a MSD set up. For some reason I can not get the distributor to seat properly. I have read several posts and tried everything including bumping the engine, and moving the oil pump shaft. I can slide my old distributor right in.. .no problems. I can't even get the distributor to make contact with the cam. So as you can tell...it barely goes in at all. Its an 86 motor that I have converted to carb. MSD distributor part number 3479. Any ideas?
Tanus
847
A to the Z
Mar 20, 2010
  • Mar 20, 2010
have you made sure the gear teeth match?
andrewb_80
38
Dayton, Oh
Mar 20, 2010
  • Mar 20, 2010
Yes, everything matches
andrewb_80
38
Dayton, Oh
Mar 20, 2010
  • Mar 20, 2010
The speed shop that installed the gear said that they measured from where the flange of the distributor seats against the block down to decide gear placement. I just noticed that the distance from the bottom of the gear to the end of the shaft where it meets the oil pump shaft is about 1/8'' longer on the new shaft.. I wonder if the angle of the distributor is not allowing the distributor shaft to go into the hole where the oil pump shaft is..?
  • dan50
  • Jul 18, 2026
dan50
P
Engine Swapping EFI distributor for carb distributor- shaft length is different
  • pindude80
  • Jul 20, 2024
Fox 5.0 Mustang Tech Jul 21, 2024
pindude80
P
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
P
Engine Carb'd 88 GT, need centrifugal advance, will an '85 Distributor Work?
  • pindude80
  • May 12, 2024
Fox 5.0 Mustang Tech May 13, 2024
limp
