Distributor install
  • Thread starter Thread starter 94GTMustang5.0
  • Start date Start date Oct 18, 2010
9
94GTMustang5.0
98
  • Oct 18, 2010
I checked around in the how-to section but couldnt find anything, can anybody point me in the direction or explain briefly to me how to install a distributor and make sure the timing is correct?
Rick 91GT
Mustang Master
95
99
PA
Oct 18, 2010
  • Oct 18, 2010
You want to bring the motor up to TDC, if you pull the spark plug out of #1 and turn the motor over you will feel pressure then it will relieve, at that point keep rotating the motor till it is at TDC on the balancer. If you look into the head or stick something in the plug hole you should hit the piston as it will be at the top of the cylinder.
Drop the dist into the motor with the rotor pointing at #1 plug wire on the cap. This will get you close enough to get it started and set the time properly with a timing light If it doesnt fire slightly rotate the dist to get it up and running, until you can verify with the timing light.. Pull the spout plug out (small plug located near the dist on a fox, over near the MAF on a SN car) and sent the timing to 10-14 degrees, tighten the dist and put the spout connector back in.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Oct 18, 2010
  • Oct 18, 2010
Just FYI, if you find that you need to pull out the oil pump shaft for any reason and can't find anything to get down in there to pull it out with...get a 1/4 inch extension and a piece of vacuum hose to fit tight over the male end of it, and use that to slip over the head of the shaft and bingo...comes right out.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 18, 2010
  • Oct 18, 2010
Putting the distributor back in is fairly simple. Pull #1 sparkplug, put your finger in the sparkplug hole,
crank the engine until you feel compression. Then line up the TDC mark on the balancer with the pointer
on the engine block.
The distributor starts out with the #1 plug wire lined up at about 12:00 with you facing it. Align the rotor
to about 11:00, since it will turn clockwise as it slides into place.
Align the distributor rotor up with the #1 position marked on the cap, slide the distributor down into the block,
(you may have to wiggle the rotor slightly to get the gear to engage) and then note where the rotor is pointing.
If it still lines up with #1 position on the cap, install the clamp and bolt. If not, pull it out and turn 1 tooth forwards or backwards and try again. Put the #1 spark plug back in and tighten it down, put the clamp on the distributor, but don't tighten it too much, as you will have to move the distributor to set the timing. Note that there is no such thing as one tooth off on a 5.0 Mustang. If it doesn't align perfectly with #1 position, you can turn the distributor until it does. The only problem is that if you are too far one way or the other, you can't turn the distributor enough to get the 10-14 degree optimum timing range.
10 degrees BTC is towards the drivers side marks.
Simplified diagram of what it looks like. Not all the marks are shown for ease of viewing.
ATC ' ' ' ' ' ' ' ' ' '!' ' ' ' ' ' ' ' ' ' BTC
---------------- > Direction of Rotation as viewed standing in front of the engine.
The ' is 2 degrees.
The ! is TDC
The ' is 10 degrees BTC
Set the timing 5 marks BTC. Or if you prefer, 5 marks towards the driver's side.
At this point hook up all the wires, get out the timing light and start the engine. Set the timing where your car
runs best. Don't forget to disconnect the SPOUT jumper connector when you set the timing, and plug it back
in when you finish.
The HO firing order is 1-3-7-2-6-5-4-8.
Non HO firing order is 1-5-4-2-6-3-7-8
9
94GTMustang5.0
98
  • Oct 19, 2010
I have heard that advancing timing gets you more HP
say, if im running 10 degrees, id get more horsepower running 14 degrees. is this true?
skunk21
1,203
Taxachusetts
Oct 19, 2010
  • Oct 19, 2010
yes you do get a bump in power and it wakes up the motor some. It's a common mod. some can run advanced timing on 87octane while most need to run super since pinging will occur. start at the base timing and advance 2degrees at atime and take the car for a ride. If the car doesn't ping then advance again if you here it ping back it off 2degrees. most people run 14-16advanced. some cars can run higher some lower depending on the motor condition, etc. I run regular and run 16* it didn't ping at 18 but I felt better running at 16.
9
94GTMustang5.0
98
  • Oct 19, 2010
hm, so all i have to do is turn the distributor to change the timing?
and i pulled the old distributor today, the inside of that thing was messed up severely. one of the metal tabs *somehow* got bent up and wrecked all the wiring and insulation on the PIP sensor.
T
thebullschmidt
65
  • Oct 19, 2010
that is correct sir something that helped me out is crawl under the front of the car and mark 14* on the balance or what ever timing your aming for then use the timing light to line the mark up with the timing pointer. slowly turn the distributor and you can watch the line move accordingly. ive heard that 14* is about the best timing to run work rather well for me.
9
94GTMustang5.0
98
  • Oct 20, 2010
you guys gotta fill me in, since im a novice here :/
How exactly do you use a timing light? do you use it while the car is running?
L
Lawbreaker5.0
543
Texas
Oct 20, 2010
#10
  • Oct 20, 2010
  • #10
Yes. Unplug the spout by the distributer turn car on and shoot the timing light down on the balancer. You need the dizzy hold down bolt slightly loose so you can retard or advance your timing. After your done don't forget to tighten the hold down bolt, recheck timing and plug spout back in
9
94GTMustang5.0
98
#11
  • Oct 20, 2010
  • #11
sounds easy enough, where do you guys suggest i order a new distributor from? i found some great deals on ebay but the TFI module on them is aftermarket. is it better to go with factory ford?
skunk21
1,203
Taxachusetts
Oct 20, 2010
#12
  • Oct 20, 2010
  • #12
Factory! I got mine from tousley ford just google them and ask for steve in parts they give a good discount.I would have to look my slip up but I payed way less than local or online. I have used them for atleast 8yrs w/o problems on many ford/ford racing items.
The timing light is really easy to use. put the lead around the #1 spark plug wire, while the car is running follow what LawBreaker5.0 stated to do. bump it up, and take it for a drive if it pings, back it of..pinging no good.
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
Engine Distributor Interchange List
  • Wayne Waldrep
  • Jun 21, 2025
Fox 5.0 Mustang Tech Jul 20, 2026
dan50
