distributor issue or?
  • Thread starter Thread starter cwdavis_02
  • Start date Start date Nov 28, 2010
C
cwdavis_02
  • Nov 28, 2010
everytime i turn the distributor when the motor is off the i can hear the fuel pump cycle on and off? Anyone know why this is?
HISSIN50
34
129
Nov 28, 2010
  • Nov 28, 2010
If the key is on, this is normal.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 28, 2010
  • Nov 28, 2010
+1. It is by design.
That way the fuel pump doesn't keep running when the ignition switch is in the Run position and the engine isn't running. It reduces fuel loss from any leaks, danger from fire or running the battery down.
C
cwdavis_02
  • Nov 28, 2010
Yes the key is in the on position. I wasn't sure if this is what's causing my hard starts. I hear the fuel pump come on when I turn the key. The motor jus spind. Spray some starting fluid in it it runs. But runs real rough. But then somtimes it will start fine when its warm but still doesn't sound to good. Any suggestions?
HISSIN50
34
129
Nov 28, 2010
  • Nov 28, 2010
How is the fuel pressure?
C
cwdavis_02
  • Nov 28, 2010
that i do not know yet. Im waiting on a fuel pressure guage. What is the acceptable psi? Is there anything else i can check while waiting for a guage?
HISSIN50
34
129
Nov 29, 2010
  • Nov 29, 2010
You could pull codes and try to run Jrichker's checklist (though without being able to test things in order of the list, it might not be very productive).
Acceptable fuel pressure is 30+ PSI with the FPR's vac-line attached. If you disconnect the vac line to the FPR, it should show about 37-38 PSI.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 29, 2010
  • Nov 29, 2010
When it won't start, do the checklist...
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 05-Aug-2010 to add check for distributor timing in paragraph 6C.
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
See the graphic for the 10 pin connector circuit layout.
The injector power pin is the VPWR pin in the black 10 pin connector.
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
C
cwdavis_02
  • Nov 29, 2010
So I can't get a fuel pressure gauge yet cuz advance does not loan them out now. But I sprayed starting fluid in it and it will start. Then cuts off. I turned the key off then back on heard the fuel pump come on. Pressed the needle in on the schrader valve and no gas came out. I also saw there was not a fuel filter on the car. Could this be the issue?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 29, 2010
#10
  • Nov 29, 2010
  • #10
From the Cranks OK, but No Start Checklist for Fuel Injected Mustangs...
"In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have."
HISSIN50
34
129
Nov 29, 2010
#11
  • Nov 29, 2010
  • #11
I'm curious - what is there in place of the fuel filter?
A pump can make noise but not move any volume.
C
cwdavis_02
#12
  • Nov 29, 2010
  • #12
The car was originally a 4cyl. They guy I got it from had converted it to a v8. He jus cut the lines and used hose clamps onto the metal lines. Since finding this I have bought a new filter will be putting it in when I drop the tank. I was thinking the pump is jus making noise but not moving any fuel. Jus wasn't sure how possible that was.
HISSIN50
34
129
Nov 29, 2010
#13
  • Nov 29, 2010
  • #13
The lines at the fuel filter have special connectors.
C
cwdavis_02
#14
  • Nov 29, 2010
  • #14
Yeah that's true. Im going to have to find new lines or use a different style filter
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
