Distributor Question
  • Thread starter Thread starter mirage86
  • Start date Start date Oct 26, 2004
mirage86
78
  • Oct 26, 2004
I'm trying to figure out the timing on a 79 model 302 that is in an 86 model stang. Turning the dist counter clockwise, I can get as far as 10 btc. I've been looking at ignition systems (dist, coil etc.) on the internet. A lot of the ones that I have seen, have a (looks like) an electric choke on the side. I'm assuming that it is for vacuum advance. Is this necessary? My dist now does not have this (May be the reason that it is running poorly) Also what is the optimal timing setting?
Thanks
NCStang86
80
selma,nc
Oct 26, 2004
  • Oct 26, 2004
Are running a carb or EFI? If u are running a carb one from a 79-84 non-roller motor should work.The thing on the side is for timing advance. U need that for it to run right.
mirage86
78
  • Oct 26, 2004
Yea it's a carb. Edelbrock 1405. I ve got another dist. that is from a 79 that has the advance on it. Should I be aware of anything before I just swap them over?
Thanks
J
JB66
565
New York
Oct 26, 2004
  • Oct 26, 2004
Make sure your timing mark is at TDC when you remove it so you can put it back in the right place. Oh! And don't drop the hold down bolt into the engine!
NCStang86
80
selma,nc
Oct 27, 2004
  • Oct 27, 2004
When u set the timing set it w/ the vacumm line off.Then connected when it is set and u should be ready to roll.
crazypete
All my crevices are greased.
Oct 22, 2004
930
Arlington, MA
Oct 27, 2004
  • Oct 27, 2004
Well, I swapped my 91 over to carb 2 years ago and could never get my vacuum advance to work. The vacuum port on the holley avengers is apparently not drilled right and gives manifold vacuum so it's crazy detonation if I connect the vacuum hose.
So I've been driving around on only mechanical advance and lemme tell ya, it's just fine. Dont try to pass in 5th gear at 1200 rpms or you will have no power but otherwise, if the rpms are like 1800 or above, you have enough mechanical advance to get the job done.
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Paint in engine bay questions
  • B0udreaux
  • Feb 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 27, 2026
AeroCoupe
