DIY intercooler question
  • Thread starter Thread starter Jaym14
  • Start date Start date Sep 2, 2009
Jaym14
296
Long Island, N.Y.
Sep 2, 2009
  • Sep 2, 2009
Looking for opinions on the feasibility of running an air-air inter-cooler directly inline between the blower (passenger side mounted centrifugal supercharger) and the intake. I'm sure it could be fabbed but would it actually work to lower intake temps? Here is a pic I photoshoped to illustrate what I mean... please forgive the crudeness of the pic.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Sep 2, 2009
  • Sep 2, 2009
with it that deep in the engine i think the vortech cooler would work better
Jaym14
296
Long Island, N.Y.
Sep 2, 2009
  • Sep 2, 2009
Well giving this a little more thought... One could rig up some small fans to the intercooler and keep some air flow moving constantly through the fins. I'm certain this would reduce intake temps.
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Sep 2, 2009
  • Sep 2, 2009
So you could suck hot engine air through the intercooler...
That setup would be heatsoaked in no time, the intercooler would be too small, why try and reinvent the wheel? Like shaolin said, the vortech powercooler would be a much better setup.
1991notchbackLX
1,483
47
48
New York
Sep 2, 2009
  • Sep 2, 2009
Ahh the rare and elusive "interheater" haha. In all seriousness though, that setup would not do much good for lowering IATs. I toyed with the idea of hacking up a WRX intercooler (the small one that pulls outside air directly from the hood scoop) and molding some kind of grate into the hood, but it would be an exercise in futility. The internal flow area of a heat exchanger that size would not have a high enough thermal efficiency to outweigh the boost pressure drop across it. It's even likely in a low boost application like yours will be, that the charger won't even be heating the intake air to a temperature higher than the air under the hood. In that case the intercooler would be a heatsink and actually perform the opposite function you intended it to (read: "interheater"). As stated earlier, the Vortech aftercooler or water/methanol injection would be much more effective for your purposes. In any case, good luck!
rbonella
409
@ home
Sep 2, 2009
  • Sep 2, 2009
I would do the Vortech Aftercooler, they're a little pricey but effective. The polished model will cost you more, but I think it would Bad A**. Good luck! Clean motor btw!!!
347_stang
15
Albuquerque NM
Sep 2, 2009
  • Sep 2, 2009
yup.. an aftercooler air to water cooler would work a TON better in this case
TechSteele
60
North Coast
Sep 2, 2009
  • Sep 2, 2009
You could start with something like this, then put your inventing hat on.
But short of the Vortec setup, i havent seen anything that short.
Pic of one on Ebay i had in watch list
There are other radiators/coolers but this one looked like the vortec. Its also not real expencive, but I would need to build or collect all the other parts, including the tubes, pump and tank for it.
Did you ever concider a Methonal Injector system? It wouldnt take up much room.
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
ACT sensor in plastic charge pipe
  • 92Rustang
  • Jul 23, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2024
92Rustang
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
W
turbo oil/cooling system question
  • wikkedturbo408w
  • Oct 22, 2020
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2020
wikkedturbo408w
W
N
Having some drivetrain issues, need some advice...
  • Nicktheqwik
  • Nov 25, 2021
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 28, 2021
Monkeybutt2000
M
