Hi, I'm replacing the 1 piece rear main seal on a 351w I'm swapping into my 95 gt. The otc 7786 tool is $100 something bucks so I'd like to avoid having to buy it. My first question is is there a simple homemade tool or method for ensuring the seal is driven to the correct depth and not damaged? I've never had to do this so I'm at a loss here sorry if this is a simple problem but I don't want to screw this up.
Also I'm also going to get a repair sleeve since I did find a slight groove on the crank that was made by the old seal. I see where I can order the repair sleeve installation tool for around $30 it looks like a white plastic disc. Does anyone know how this tool is used and can explain it to me?
Lastly I was going to get a teflon seal from autozone since I heard they are the best. I also heard that I should install it dry and not oil the mating surface between the seal and the crank. Is that correct? Also should I use rtv or something between the seal and the cap? Thanks for any help on this guys I'm probably gonna pull all my hair out if I have to tear the engine out because of a leaking rear main seal.
