Do 1.6 rolloer rockers clear stock valve covers???
YES... there are a bunch of threads about this very subject on here. I have 1:7 crane/Cobra ones on my car with the stock covers. No clearence issues at all. No mods to the inside of the cover. Just a regular rubber/cork gasket.
There is very little room under the OEM VC's :bang:
Some RR's are bigger than others ;)
I could not say about Scorpion peds :nono:
but
I can tell you my Scorpion Stud Mount RR's are very large :eek:
My guess would be ... they won't fit :shrug:
I'd do a search using Scorpion on all the 94-95 boards :D
Grady
i was using 1:7 proforms(junk) and they hit...... so i got a set of fox body V'C's.
But now im using crane 1.7's and as far as i know, they will fit because 94-95 cobras came with them and used the stock valve covers
I installed 1.7 proforms a couple weeks ago and got them to fit by working four of them a little. I used a dremel and ground an angle on the ones at each end of the head so the VC would fit. I also used a double thick VC gasket. I didn't have to remove the oil baffle. I took pics of what I removed from the roller rockers but they're at home. I'll have to post the pic later.
