do I have 3:73 gears?
I just bought a 1992 GT, has the 5 lug conversion, the guy says it has a 3:73 gear ratio, what is the easiest way to confirm that? counting the teeth? rotating the tire so many turns? the car is a daily driver so the quickest way to tell would be great, any help would be great!!!!
:SNSign:
This is what you do. Put the rear of the car on jackstands. Take a white crayon or piece of tape and mark the tire at one location and the dirveshaft at one location. This may take more than one person but turn the tire exactly one full revolution. Count the number of revolutions that the drive shaft makes during the single tire revolution. If you do have 3.73's then you will see the driveshaft turn 3 and 3/4 times for every 1 revolution of the tire. Simple and quick
I wasnt trying to be a wise ass. It wouldnt hurt to pull that diff cover to change your fluid either. When you do this, more than likely the gear ratio will be stamped on your ring gear.
...unless the tires mounted on those 18" wheels don't have the same total outer diameter as the stock-sized tires, or the speedo gear was never swapped out for a proper number-of-teeth gear to go with the rear gear ratio.
The highway method could work for a so-so guesstimate, but you'd have to have the help of another driver with a walkie-talkie and another car that you KNOW has an accurate speedo. Get on the highway, have them set the cruise control at whatever specified speed (at least 55 MPH, probably better at 70 MPH), and then match their speed. Radio to them when you're set and cruising in 5th gear, and then record what your RPM's are, and what speed you're both going. Then, consult a chart (it's been posted a couple of times recently in prior posts) showing RPM's, MPH, and gear ratio. I won't say this is more accurate than any other method, but it's just another way of doing it - my buddies and I used this method while we were driving to the WFC9 last year, comparing Pat's and Jason's notches' speedo accuracy against Rob's bone-stock (at the time) '04 Mach 1.
Of course, this only works if you're running a stock-geared tranny (AOD or T-5). If you're running with a T-5 with some freaky internals, or a 4-banger T-5, then you're probably just better off with the first method of counting driveshaft revolutions per tire rotation.
