Do i need a new clutch?
jstang209
Jun 3, 2004
640
Stockton 209
I have a real bad leak from my rear main seal. My somewhat new LUK clutch is already starting to slip!! bad 2.. Do u think its just slipping becuase of the oil leak? When i replace the seal can i just clean off the flywheel and disc if there covered in oil or should i replace the clutch already? I've only had it a couple of months!!
If your clutch has oil all over it you will probaly need a new one. But i would try adjusting it frist some one told me one time that you pull up on the clutch pedal to adjust it. Im not sure on that.
I agree, I've seen it where the rear main seal leaks and it gets on the clutch. Especially if its fairly new.
