do i need the canister thing
  • Thread starter Thread starter murphmaster5
  • Start date Start date Jan 9, 2006
M
murphmaster5
115
PA
Jan 9, 2006
  • Jan 9, 2006
i deleted all my emission and i was wondering i think its called fuel somthing canister do i need that cause i got rid of it and could someone tell me what it does
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 9, 2006
  • Jan 9, 2006
Charcoal canister - one 3/8" tube from the bottom of the upper manifold to the rubber hose. Rubber hose connects to one side of the canister solenoid valve. Other side of the solenoid valve connects to one side of the canister. The other side of the canister connects to a rubber hose that connects to a line that goes all the way back to the gas tank. There is an electrical connector coming from the passenger side injector harness near #1 injector that plugs into the canister solenoid valve. It's purpose is to vent the gas tank. The solenoid valve opens at cruse to provide some extra fuel.
It does not weigh but a pound or so and helps richen up the cruse mixture. It draws no HP & keeps the car from smelling like gasoline in a closed garage. So with all these good things and no bad ones, why not hook it up & use it?
M
murphmaster5
115
PA
Jan 9, 2006
  • Jan 9, 2006
okay that suck cause cut everything going to and threw most of it away what should i do please help i didn know it was inportant what should i do all i have is the canister not the valve or the conector please help i was noticing a gas smell and am i loosing power not having this thanks
Euphoric306
905
  • Jan 10, 2006
what about these people with show engine bays... are they still runnin with teh canister or did they eliminate it somehow for good looks?
HISSIN50
34
129
Jan 10, 2006
  • Jan 10, 2006
I have the feeling they vent the tank as an open system. One could hide the canister in the fender (etc) and run the line to the plenum up the back side of the motor and to the intake that way. For a total show car, I have to say that I would remove the stuff myself.
EDIT: See Jrichker's important consideration below (post 11).
DmnStr8
NH
Jan 10, 2006
  • Jan 10, 2006
The previous owner of my car deleted it. I dunno why. I really wish it was there cause the car reaks of raw gas sometimes. All he did was coil the rubber tube up and tape it to the tank.
The car seems to run fine but I have never driven any other 5.0 so I dunno.
Would this cause it to run lean at cruise? Should I go visit a junk yard and get it put back on?
Sorry to Hijack the tread.
Euphoric306
905
  • Jan 10, 2006
hmm it just seems to me that venting the gas tank would throw a CEL. i know when my canister solenoid was blown it was throwing a code, so how would one bypass such things?
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Jan 10, 2006
  • Jan 10, 2006
Mine is hidden away in my fender, I had to put it there to mount my methanol pump.
stangjunkie
381
  • Jan 10, 2006
well long story short my dad is building a kit car cobra which uses a fox as a donor car, when we vented the gas tank we did it at the tank and ran the line out the back just to give it a vent. we put a small engine gas filter and a check valve so were not dumpin straight gas when we hard corner or somthin.... maybe maybe not work i dunno
HISSIN50
34
129
Jan 10, 2006
#10
  • Jan 10, 2006
  • #10
I dont see it causing an issue if the system is not there. Both of my stangs had disintegrated purge lines (the line from the cannister to the solenoid) so I was not really getting that benefit of the collected vapor at cruise - I really did not notice anything.
OBD-II cars have MUCH more finicky EVAP systems (with dedicated monitors, etc) and those throw codes all the time. I cant say whether the fox will or not. For something like the kit car, I have not looked or thought about it, but I wonder if a resisistor or something could be used to trick the computer into thinking it is working. I would need to read up on how the solenoid works first.
I have ALWAYS wanted to put together a kit car for some reason - real satisfaction in installing every single piece if you ask me. I dont think I have the nerves to cut body panels (like doors), as you have to do with some kits. But other than that, it would be a hoot!
Good luck.
EDIT again: See Jrichker's information below (in post 11).
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 10, 2006
#11
  • Jan 10, 2006
  • #11
The only other possible problem with no working carbon canister is the stinky fuel vapors. I would be a little concerned about parking the car in the garage if I had a gas water heater in the garage. Some cars really have a gasoline smell to them if they are parked in a tightly closed space.
It ranks right up there with not parking the lawn mower or garden tractor in the same garage as a gas water heater. The gas water heater pilot light is an ignition source for gasoline vapors. It may never happen, but I wouldn't want to chance it.
jammer84_03
468
#12
  • Jan 10, 2006
  • #12
it was weird with my motor originally....when i had the hole unplugged the car would lope a ton more and seemed to have a ton more torque, now that i have a canister back on or when i had it jsut plugged, the car seems to die down a lil
HISSIN50
34
129
Jan 10, 2006
#13
  • Jan 10, 2006
  • #13
That is an outstanding point. Kudos to you for even thinking of that - we both live in hot climates, and that sort of stuff does not enter into my thinking anymore (ya' think it would after having grown up in Alaska). No water heater for me in the garage either. I will amend my above-post to mention seeing your post here. Very good point Jrichker!
M
murphmaster5
115
PA
Jan 10, 2006
#14
  • Jan 10, 2006
  • #14
does anyone have a pic of the valve and the conector thanks
Engine Vacuum reserve capacity question
  • Mcmahst
  • Apr 24, 2025
Fox 5.0 Mustang Tech Apr 27, 2025
Mcmahst
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
J
Greetings from Central Florida!
  • JediMeister
  • Thursday at 9:40 PM
  • The Welcome Wagon
The Welcome Wagon Friday at 4:06 PM
Rdub6
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
Supercharger and What else do I need? 1990 Saleen Vert 5spd
  • AlbertaGolfer68
  • Aug 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
General karthief
