here it comes....theblkhorse said:there is a recomended break-in,run the gears to operating temp,let cool completly,then take it easy for 50 miles or so
traini agree with that.codyGT said:There is no real " Break-In" period but. Don't beat the he!! out of it right away. Take it easy for a little while so you can make sure they are set up correctly.
Jackie Chan said:here it comes....thetrain
Call it what you want.
, because the ring and pinion are both already heat treated @ 1800* for 16 hours before they are shot peened and lapped.
miles before I hammered on it after I got my rear axle built. First time I got on it was down the 1320'.I will throw theGT JAY said:Call it what you want.
I was told by several people(engineers,gear analysts, and garage mechanics, some with 35+ years) at my work(Ford Sterling Axle Plant) to take it easy for at least 200 miles. Even though a pattern is cut into the gear when it is lapped, they still wear in a bit once the axle is put together and driven. It's not much, but if you beat the crap out of it right away you could cause the gears to whine.
The whole heat up cool down theory is, because the ring and pinion are both already heat treated @ 1800* for 16 hours before they are shot peened and lapped.
I took it easy for 225-250miles before I hammered on it after I got my rear axle built. First time I got on it was down the 1320'.
flag. I know a lot of people that have had gear swaps and not one of them has had whine or anything after install and no break in. I remember reading about when all of the scientists and researchers in the world said the world was flat....your vast knowledge base of friends must be direct descendents of themJackie Chan said:I will throw theflag. I know a lot of people that have had gear swaps and not one of them has had whine or anything after install and no break in. I remember reading about when all of the scientists and researchers in the world said the world was flat....your vast knowledge base of friends must be direct descendents of them
Whatever Mr. Know It All. Is there really such a job / position ? Nevermind, I'm sure of what your answer is...GT JAY said:gear analysts
yes maybe, perhapsGT JAY said:Whatever Mr. Know It All.
Maybe you should call Ford World H.Q. and tell them that they need to fire everyone who works in the Gear Lab and Experimental Garage at Ford Sterling Axle because it's obvious that none of them know what their talking about. Then maybe they'll hire you since you seem to think you know EVERYTHING!
as far as the powershifting thing, my clutch is fine....(knock on wood) but the damn tranny keeps pooping out on mecodyGT said:Wow, Why doesn't everyone just do what they feel is best?
If you want to beat your new gears right away don't complain later. If you want to take it easy and make sure eveything is 100% that is more than OK too.
It's just like power shifting some belive it's the only way / best way to shift. But then again most of them have a " My clutch is toast at 30K " post some time or another.
