do lifters bleed down
  • Thread starter Thread starter ONEBADPNY
  • Start date Start date Sep 30, 2005
ONEBADPNY
195
FREMONT, NEBRASKA
Sep 30, 2005
  • Sep 30, 2005
i just went back over my noisey rockers again and everything tightened up fine. they are ped mount turn about 3/4 turn to 19ft.lbs. after the motor cycled though all of them again i could move all the rocker up and down on the pushrod. idon't know why because after i set them i could not move them at all right away. i was thinking i needed longer pushrods so i checked again. anyone know whats going on here.
ONEBADPNY
195
FREMONT, NEBRASKA
Sep 30, 2005
  • Sep 30, 2005
anyone????
ONEBADPNY
195
FREMONT, NEBRASKA
Sep 30, 2005
  • Sep 30, 2005
oh boy i just started it and they are way louder this time. same noise i was hearing before but louder. at least i know they are causing the noise. going to order up 6.300 trickflow pushrods now........
ONEBADPNY
195
FREMONT, NEBRASKA
Sep 30, 2005
  • Sep 30, 2005
i tried setting them again and nothing better. maybe i don't know how to set them right.
8950HO
658
  • Sep 30, 2005
Yes,hydraulic lifters will bleed down when you go to set them up because when you`re moving the engine by hand to set up a certain cylinder/valve...other valves are being opened,which puts a load on the lifter and bleeds it down because there`s no oil pressure when the engine is not running to keep it pumped up.
ONEBADPNY
195
FREMONT, NEBRASKA
Oct 1, 2005
  • Oct 1, 2005
but my problem now is that after i reset them all now i can move them up and down after i set them. when i start it it is tickin like crazey.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Oct 1, 2005
  • Oct 1, 2005
Are you certain that you have each lifter on the base circle of the cam when you are installing them? Proper procedure for installing them below; it's not necessary to have oil in the lifters for the installation.
To install pedestal mount rockers:
1) For each pair (int/exh) be sure you rotate the engine so the lifters are on the base circle of the cam - this is very important. When you install the rockers, both valves must remain closed. Neither lifter can be on any part of the cam lobe - they MUST be on the base circle.
2) Install the rocker and bolt it down to zero lash. Zero lash is reached just when you eliminate the gap between the pushrod and the rocker and the valve stem and the rocker. Tighten with one hand and 'rock' the rocker with the other hand. Just when you reach the point that you can't rock the rocker anymore you're at zero lash.
3) Now - put your torque wrench on it and tighten to 18-20 ft-lbs. while counting the number of turns it takes to reach that torque. It should occur between 1/4 turns and 1 turn. If it takes more than one turn, use a shim to raise the rocker. For each .030" shim you use, you'll reduce the number of turns to torque by about 1/4. If it takes less than 1/4 turn, or you have trouble reaching zero lash even with the bolt torqued all the way to 18-20, then you need longer pushrods.
4) If all goes well on the install, crank it up. If some make noise let the car warm up completely. Then (unfortunately) go back through the install procedure with the components warm. That will usually quiet them down.
Mine has 11 with no shims at all, 4 with one .030" shim, and one with 2 .030" shims. And I had to do the final install with it hot to get them quiet. That approach has them all hitting the required torque within 1/2 to 3/4 turns.
I have a Buddy Rawls custom cam with VERY steep ramp rates, 1.7 roller rockers (pedestal Cobra type), and stock lifters. It runs just about as quiet as it did stock.
ONEBADPNY
195
FREMONT, NEBRASKA
Oct 1, 2005
  • Oct 1, 2005
thanks michael i took it apart again now it is just the exhaust loose this time. before it was both so i am half there. i followed flowtechinduction procedure but maybe i need both valve closed instead. i will try that this time. one way or the other i'm not giving up yet. i must not have had them right from the beginning either.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Oct 1, 2005
  • Oct 1, 2005
Pull all the plugs to make turning over the engine with a socket on the balancer bolt easier. Start with #1. Rotate the motor to the compression stroke - both valves will be closed. Do #1. Then follow the firing order (1-3-7-etc.) -- this will reduce the amount of engine turning you have to do to close the next pair before installing the rockers. Are you certain you understand how to determine if the lifter is on the base circle of the cam?
ONEBADPNY
195
FREMONT, NEBRASKA
Oct 7, 2005
#10
  • Oct 7, 2005
  • #10
thanks for the help Yount. i reset them today after the engine was warm. made a big difference. i ended up using some smaller shims on most of the intake valves and one exhaust. got them all set with 1/2 to 3/4 turn past 0 lash. i think my main problem was that i was setting them by turning the pushrod and not rocking it instead. i had them all set to far because after rocking them i still could twist the pushrod easy. i went off crane cams tech page and feel real good about how they are set now. still kinda noisey but little better than it was. i think i am going to change exhaust gaskets next and try to double them up this time.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Oct 7, 2005
#11
  • Oct 7, 2005
  • #11
Extra exhaust gaskets rarely does the trick - sounds like the flange(s) are warped/not true/not flat. When you get the header off put a straight edge on the flange. If it's not true, it's pretty cheap to have a machine shop mill them flat. They'll seal perfectly and bolts backing out usually won't be a problem either.
ONEBADPNY
195
FREMONT, NEBRASKA
Oct 7, 2005
#12
  • Oct 7, 2005
  • #12
they are long tubes so i might not take them all the way out. i think i am going to get some bbk or ford shorties to make life easier.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Oct 7, 2005
#13
  • Oct 7, 2005
  • #13
Crane cams have issues with pushrod lenght, some poeple need longer pushrods, like yours truley.
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
L
A/C doesn't work after long drive
  • lking78
  • Jun 23, 2026
  • SVT Tech Forum
SVT Tech Forum Jun 30, 2026
