do they make a egr delete tube for our car???
i had problems when i tried to cap off my egr. the only way to properly remove it is to turn it off with a tuning device. i am using the adaptor from profesional products to connect the tube. you can get it from 50resto.com
im confused by your question you can plug the tube by reusing the threaded end and blocking it with a penny works great or you can get aftermarket headers for a 93-earlier and then you wont even have the tube to worry about
ok.....i ordered one.....thanks for all the help....and yes it won't fit with my spacer...i tried to build my own by welding a copper coupling but i couldn't get the exact fit of the tube to flange out...then i tried using a high heat rubber tube as a coupling after i flushed up both sides, but the tube gets to hot....so i could either take off the spacer and get another tube or i could delete it....
jimmy
