It's a requisite mod if you're going with nitrous or a blower/turbo. The cooler heat range helps keep the tip of the plug from getting hot enough to cause pre-ignition which can be catastrophic on FI engines.
It's not required and not even really desired on most normally aspirated combos because cooler plugs are also more likely to suffer fouling.
