  • 1994 - 1995 Specific Tech
Does this really work?
  • Thread starter Thread starter SN95StangMan
  • Start date Start date Nov 2, 2004
SN95StangMan
1,292
Lynwood, CA
Nov 2, 2004
  • Nov 2, 2004
K
King Cobra 22
175
  • Nov 2, 2004
I heard from somebody to take a coffee can, bolt it somewhere under the hood and run a fuel line in it and coil it up then add dry ice to the can and it will give a bit more hp.Does this really work?
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Nov 2, 2004
  • Nov 2, 2004
From what I gathered from that, you mean to coil the fuel line inside the coffee can & add dry ice to it to cool the fuel. It won't make a difference at all. Actually, it will probably make your car run rich
Since the car calculates a/f ratio by measuring the incoming air charge, and injecting a specific amount of fuel to make it combust, this will make the amount of fuel coming into each cylinder be more than normal, because the fuel is more dense, so a injector pulse duration of .5 seconds will now have the amound of fuel of a injector pulse width that lasts .6 seconds (numbers made up, just making a point).
So, unless you get a dyno tune for the change in fuel, you will run rich. But even with a tune, your car will not produce more power.
Fuel doesn't get very hot compared to the incoming air charge. Also, since there is about 13-15 times the amount of air in each cylinder per combustion cycle, it doesn't make sense to try to play with the amount/density of fuel coming in.
It all comes down to sucking the most air per cycle. The car can always add more fuel at will.
Scott
K
King Cobra 22
175
  • Nov 2, 2004
Scott
Thanks for clearing that up!
mstangfrk95GTS!
203
  • Nov 2, 2004
its a old school trick you see alot on carbed/sc cars......it was actually called a Cool Can.
it doesnt add horsepower, but it does help prevent vapor lock.
just cause it wouldent work too well on a EFI mustang doesnt mean its a useless idea, yall could be a little more open minded.
NIN
452
moorhead MN
Nov 3, 2004
  • Nov 3, 2004
Try the alcohol injection for cooling the air charge. I have heard of it making decent power. Not speaking from experience though.
illwood
636
Worcester, MA
Nov 3, 2004
  • Nov 3, 2004
I was under the impression that the alcohol mist was mainly to cool the heated air from t/c and s/c applications. I had never heard of anyone running a n/a car with it.
slvrbullit302
986
Alabama
Nov 3, 2004
  • Nov 3, 2004
Snow performance sells their kit for N/A combinations as well as boosted combos.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Nov 3, 2004
  • Nov 3, 2004
It is useless as far as a street car is concerned. It's also useless as a horsepower adder.
Vapor lock? What is that????? Damn carbed vehicles.....
I was open minded about it. I thought about it's application to our cars, and I logically deduced that it would not be practical. This is the 1994-1995 mustang forums......Right?
Scott
mstangfrk95GTS!
203
#10
  • Nov 3, 2004
  • #10
im just saying that if you have a car, usually carbed yes...that it can help cool down the gas lines so that it doesnt boil the gas in the lines.
anyone notice that in the summer your car with dumps runs kinda crappy?? its cause the ambient temp of your gas is higher, almost to the point of turning into a vapor maybe.
and no reason to have a attitude i was just pointing out that it DOES have a function and it DOES do something.
E
EpiKk3
405
#11
  • Nov 3, 2004
  • #11
Calm down ladies, I had never heard of this.. learned something tonight..
What Movie Would You Make?
  • Noobz347
  • Oct 9, 2026
  • Off-Topic Hangout
Off-Topic Hangout Oct 14, 2026
DadLife0724
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Guess you can polish a turd after all...
  • DadLife0724
  • Aug 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2025
DadLife0724
D
Speedo and tach dead
  • Davinrobinson1
  • Jul 19, 2026
1994 - 1995 Specific Tech Jul 26, 2026
fasterthangas
F
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
