Doesn't Charge enough!
  • Thread starter Thread starter mrlineville
  • Start date Start date Aug 20, 2009
M
mrlineville
  • Aug 20, 2009
Hi everyone. Lets get right to it. I need help. Mustang is a 65 fastback V8 car. New battery, that tests good. New alternator that tests good. New voltage regulator, not sure if you can test them. The car charges 12.3 - 12.5, which is not enough. I have worked on this for many months without success. Tried connections, grounds, etc. Any tips or suggestions?
Tim65GT
1,149
West Texas
Aug 20, 2009
  • Aug 20, 2009
12.3 to 12.5 is not charging.
Charge voltage should be 13.5 to 14.5V
Take a close look at all the wiring at the alternator and voltage regulator for a loose, frayed, burned, dirty, corroded or broken wires and connectors.
10secgoal
2,801
San Diego
Aug 20, 2009
  • Aug 20, 2009
Put a jumper wire on the wiring on your plug going to the reg. Pull it it out, and jump the two outside wire. You should see a huge jump in voltage. Don't hold it it there though lol. That is the alt wide open. It that works, the wring and Alt is fine. It's the reg. But here is something missed. Grounding the alt is not just grounding like an engine. You MUST ground it with the stud marked"GRD", or it won't charge. The voltage will barely move if it's not grounded there, AND everything will test correctly like what you have going on there.
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
C
Stock 1993 charging issue at idle
  • Charlie1
  • Sep 21, 2025
Fox 5.0 Mustang Tech Sep 24, 2025
Mustang5L5
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
F
Alternator Not Charging
  • Fri Guy
  • Aug 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 31, 2025
AeroCoupe
