  • 1994 - 1995 Specific Tech
doing up the rear end
  • Thread starter Thread starter viridionplague
  • Start date Start date Oct 31, 2007
V
viridionplague
98
  • Oct 31, 2007
so recently the rear end of my car is shot, so ive decided to upgrade to 31 spline stuff and see how it goes. i only bought the car about 3 months ago without a warrenty but i called up the dealer and they said they would foot some of the bill
this is what im planning on going with
Eaton Differential, Posi Performance, Limited Slip, 31-Spline, Ford, 8.8 in., Each $479.95
http://store.summitracing.com/partdetail.asp?part=ETN-19588-010
Gear, Ring and Pinion, 3.55:1 Ratio, Ford, 8.8 in, Set $195.88
http://store.summitracing.com/partdetail.asp?part=RMG-4901031
Gear Lube, GL-6 Gear Oil, 75W140, Limited Slip, Synthetic, 1 qt., Each $9.95 $29.85
Axles, 31-Spline, Rear, Ford, Mustang, 8.8 in., Kit $279.99
http://store.summitracing.com/partdetail.asp?part=SAG-EV83
it comes out to just under 1000 bucks and the shop is charging me 350 for the install
kind of wondering if this is a good setup and a good price or if i missed anything or anyone would recomend a diffrent part or whatnot
thanks for the time
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Oct 31, 2007
  • Oct 31, 2007
gears?seals?
go-stang5.0
2,244
Glenview,Il
Oct 31, 2007
  • Oct 31, 2007
hes got gears...but yea wheel bearings and seals and possibly shims
F
fish254
237
Brooklyn NY
Oct 31, 2007
  • Oct 31, 2007
i just did mine i used the ford track lock unit from the 03-04 cobra really strong great for the price
http://www.stangmods.com/FRPP-03-04-Cobra-Carbon-Fiber-Clutch-Tlok-p/m4204f318c.htm
and i used 31 spline superior axles also great piece
toyman
1,944
54
79
Vernon BC
Oct 31, 2007
  • Oct 31, 2007
You might want to check out the FRPP complete assembly if you really don't need the 31 spline axles. Part M-4006-B373. List at $875.00. I would think that Summit probably has a better price. Just drop the old and bolt in the new. I did that earlier this year when I managed to bend the axle housing.
WHITE94COBRA
816
HUNTINGTON BEACH
Oct 31, 2007
  • Oct 31, 2007
I just finished my rear end rebuild on my 98, I got the mosier axles, an auburn diff, and all new seals, syn oil, and bearings. Summit has a gear kit that comes with richmond gears, syn oil, seals, bearings (accept axle bearings) and Trickflow diff cover for $410. I have about 1k miles on the rear now, with zero issues, and that whole myth about the richmond gears being noisy is wrong. My 94 has ford racing gears and is louder than the richmonds. Ohh and it's 31 spline as well.
V
viridionplague
98
  • Nov 1, 2007
the axels actualy come with the bearings and seals, and in the future im going with a 408 stroker then twin turboin that so i think the 31 spline is in order for future needs
the reason i did not go with the full unit is because it does not come with the axel shafts and i wanted to go to 31 spline while im here and i wanted something a little stronger than the trak-lok ford has
Black95GTS
1,644
Marlborough, MA
Nov 1, 2007
  • Nov 1, 2007
My .02 is that you have a good plan and 350 for that install is extremely reasonable. Often times install for the gears alone is about that much. I personally like the Auburn units however I have no scientific information to back that up other then I know people that run them with great success.
If you are going with a TT 408, I'd read up on Turbo Mustangs and ask around for rear end ratio advise. 3.55 is most likely fine but because I'm afraid to do that work myself I would only want to do it once... I hate paying someone else to work on my cars!
Adam
V
viridionplague
98
  • Nov 1, 2007
part of the reason i choose the reason i choose the 3.55's is most people with say 3.73 for n/a cars and 3.27 for turbo applications.
i probably wont be in the turbo realm for a while being that i need to get the swap done first drive that for a bit then turbo in the future
so i comprimised with 3.55 kind of uncommon but should be fun both n/a and turbo in the future
V
viridionplague
98
#10
  • Nov 1, 2007
  • #10
actualy with a little more research im going to go with the same setup but getting everything through strange instead
they quated me at 860 for parts and around 900 with shipping anyone had any experiance with there products or heard anything, i havent seen to much on the forums about them
Black95GTS
1,644
Marlborough, MA
Nov 1, 2007
#11
  • Nov 1, 2007
  • #11
Strange axles are suspect at best. Do a search for KillerCanary and strange axles and read about what his father went through using them.
Adam
Drivetrain Rear end Question
  • Aoneill5.0
  • Nov 3, 2022
2K
Fox 5.0 Mustang Tech Nov 5, 2022
Rdub6
For Sale 1986 Capstang (Part Capri & part Mustang) $12,000 Galena, Ohio
  • BubbaG
  • Aug 7, 2022
2K
Fox Body Mustangs For Sale (1979-93) Aug 7, 2022
General karthief
mustang gt rear end/differential rebuild cost vs doing it myself
  • sharpright
  • Nov 4, 2020
15K
1996 - 2004 SN95 Mustang -General/Talk- Jun 22, 2021
Mustang5L5
C
For Sale Moser 8.8 Complete Rear End
  • CobraNav
  • Mar 12, 2020
  • Drivetrain Parts
6K
Drivetrain Parts Jul 7, 2021
southallfoxbody1320
N
SOLD Supercharged 1989 SSP Coupe $13,500 obo
  • notchlubber
  • Jul 17, 2018
13K
Fox Body Mustangs For Sale (1979-93) May 28, 2020
notchlubber
N
