  • SN95 4.6L Mustang Tech
Door Adjustment
  • Thread starter Thread starter Barjam
  • Start date Start date May 13, 2004
Barjam
38
  • May 13, 2004
Are the doors on our mustangs very adjustable? I noticed on my car that the passenger side door angled in slightly on the top. Iit looks like I could loosen the 4 bolts on the door (not the frame bolts) and tilt it back (then adjust the striker area). Is that all there is to it?
Is it a lot harder than it sounds?
Thanks
G
geegee
2,015
near Oklahoma City, OK
May 13, 2004
  • May 13, 2004
Thanks
In simple terms, no. However be aware that moving the door impacts the entire fit including window glass.
Jeff
M
MustangJunkie
97
Northern VA
May 13, 2004
  • May 13, 2004
Ford won't do it for you even if the car's under warranty. They'll simply state matter-of-factly that it is "within spec". You'll either have to do it yourself or get a body shop to do it.
My car seems as though it was put together on a Monday morning or late Friday afternoon. The lines on my car are not as straight as I've seen on other Mustangs. I got no denial about the asymmetry or crooked lines from my Ford dealer, simply it's "within spec". Pisses me off. But I guess I'm just being picky. I paid good money for my car, shouldn't i expect it to be perfect?
Barjam
38
  • May 13, 2004
Jeff
Thanks, Yea, I had planned on adjusting the glass anyhow. I hoping to get rid of a little leak up front doing that.
T
tjm73
2,418
Rush, NY
May 13, 2004
  • May 13, 2004
Thanks
You can adjust them, but it's a 2 person job. You can not adjust the windows independently of the doors.
Barjam
38
  • May 13, 2004
I pulled the top of the door out this evening, and oddly enough it actually helped the window placement (I was having a minor leak problem before). My problem was the top position was pushed in about 1/4 of an inch or so. All I did was loosen up all four bolts holding the door and pulled it out until it lined up.
I poured a few cups of water over the door so hopefully the leak goes away too, if not I will adjust the window this weekend.
Thanks for the advice everyone.
J
Adjustment of driver front door
  • JJHstang
  • Feb 23, 2025
1965 - 1973 Classic Mustangs -General/Talk- Mar 2, 2025
89ripper
A
Engine 04 GT timing chain issue
  • AwesomeX1103
  • Sep 3, 2025
SN95 4.6L Mustang Tech Nov 5, 2025
R
85 T-Top doors hard to close... Just how it is?
  • rwordenjr
  • Dec 5, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 7, 2024
rwordenjr
R
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Foxbody adjust alignment
  • Creomod
  • Jun 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 14, 2025
2000xp8
