Door Lock Actuator Install Problem 1986 GT
sam woodson
10
I am trying to install a new drivers side power door lock actuator in my 1986 Mustang GT convertible.
I drilled out the old rivet. (OOPS, later I read I could have reused the old bracket and just slipped the actuator out. No instructions came with this.)
I bought a rivet, but now see I don't have the giant rivet tool required. So, I found a short bolt that had the right threads and screwed it in, I added a nut on the inside of the door just to be sure.
The door lock actuator from FoxMustangRestoration is actually a generic Ford actuator that comes with a bunch of rods. It appears the shortest one is correct.
I have the actuator in place. I can lock/unlock a couple times then it just quits, unless I manually push it down, then it will work again a few times.
Any ideas to get this working properly so I can put the door panel back on and be done with this.
Thanks,
Sam
Feel the pain in your wallet? You just got shafted...
Follow this link to fix your door lock actuator problems http://bellsouthpwp.net/l/r/lrichker/Mustang_tech/door_actuator_fix/1_of_8_door_actuator.htm
Stuck with door lock actuators that don't work and don't want to pay the $50+ for a new one? Tried the junkyard ones and found that they last six months and freeze up?
A new actuator for less than $5. Fix one side for $18, do both sides for only $25. I don't sell parts, I don’t make any money off of the upgrade, I just tell you how to do it cheaply and easily.
