Door Lock Actuator Problems
  • Thread starter Thread starter Black Sun 5.0
  • Start date Start date Oct 5, 2007
Black Sun 5.0
1,337
L.I., N.Y.
Oct 5, 2007
  • Oct 5, 2007
OK, so I don't know how I got myself into this situation since I've replaced actuators in the past with no real problems. I have two problems: 1 is that the driver's side door that I replaced the actuator in only locks, but doesn't seem to be able to unlock. Is there any way to make an adjustment? 2, I lost the little pin for the second actuator, fell out on a black leaf covered driveway. Anyone know where I can get one of these little pins? In a totally unrelated question, does anyone also know where I can get the little plastic/rubber piece that covers the end of the hood prop arm? I had a shop gouge out my freshly painted hood with it. Yeah, war has been declared. Thanks.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 5, 2007
  • Oct 5, 2007
1.) Use a test light to check and see that you have power in the unlock mode. connect the test light across the two pins inside the electrical connector for the actuator.
Follow this link to fix your door lock actuator problems http://bellsouthpwp.net/l/r/lrichker/Mustang_tech/door_actuator_fix/1_of_8_door_actuator.htm
Stuck with door lock actuators that don't work and don't want to pay the $50+ for a new one? Tried the junkyard ones and found that they last six months and freeze up?
A new actuator for less than $5. Fix one side for $18, do both sides for only $25. I don't sell parts, I don’t make any money off of the upgrade, I just tell you how to do it cheaply and easily.
Here’s a picture of the new actuator installed:
Black Sun 5.0
1,337
L.I., N.Y.
Oct 5, 2007
  • Oct 5, 2007
There's power, it just seems that I didn't properly adjust something correctly when I put the new actuator in. You can see the door lock pulling down, but not far enough where the door is actually locked. As for the upgrading of the actuators themselves, this car is a garaged weekend car now, it was the previous owner's daily driver, so I'm hoping that lack of exposure to any elements will preserve these actuators a lot better.
2SteelHorses
68
  • Oct 17, 2007
Yeah I'm trying to get a handle on my door lock issues too. I have read jrichker's fix and I'm gonna go that route with his plan, but I want to try and remove the old actuator from the mount without drilling the rivet. Some mentioned they got them out easily by prying. What did you guys use? HISSIN50 you out there, what did you use?
Black Sun 5.0
1,337
L.I., N.Y.
Oct 17, 2007
  • Oct 17, 2007
I was able to resolve my issue and both actuators have been replaced. Be careful with prying, you don't want to bend or break anything. I've replaced old actuators without drilling, they pop just pop out by the rubber boots on each side of the actuator. Then, just pop the new one in. My problem was that I screwed up which hook I used and had to get it out. FYI if anyone was curious, I found the little divet that I dropped the week prior. I got lucky.
SuperStang83
1,693
Boyertown, Pa
Oct 17, 2007
  • Oct 17, 2007
You could probably just find a vacuum plug to put on the end of the prop rod.
2SteelHorses
68
  • Oct 17, 2007
Black Sun 5.0 what did you use to pry out the actuator?
Black Sun 5.0
1,337
L.I., N.Y.
Oct 18, 2007
  • Oct 18, 2007
I didn't pry anything, the actuator will just pop out from the mount. Just use your hands and push the actuator out of the mount. It's only held in place by some rubber stoppers.
2SteelHorses
68
  • Oct 18, 2007
Damn. Mine wouldn't budge when I tried to remove it with my hands.
Black Sun 5.0
1,337
L.I., N.Y.
Oct 18, 2007
#10
  • Oct 18, 2007
  • #10
Typically, the actuator would have to be pulled down to pop it out. I tend to flip the mount over so the actuator stays in place better and doesn't come loose. If it's the original actuator, you should just have to push down on it. Just be careful, the mount is plastic.
2SteelHorses
68
#11
  • Oct 18, 2007
  • #11
Well I just went out there this afternoon and got it out. Not all the mounts are plastic from what I have seen, but mine are. I originally used my Dremel and cut off wheel to cut the twisted rod that comes out of the actuator and connects the locking mechanism. Since the actuator was frozen I need to release the tension by cutting it, which allowed me to lock the door manually. Anyway I couldn't get enough leverage pushing down on the actuator and tried several times. So I took a screw driver that allowed me to put enough torque on one side to slip the actuator out off one of the rubber grommets from the mount. I used it like a little pry bar but made sure I didn't put to much pressure on the mount. One side came out and made it really easy to slide the other side from the mount.
Black Sun 5.0
1,337
L.I., N.Y.
Oct 19, 2007
#12
  • Oct 19, 2007
  • #12
Good luck, the rest should be pretty easy. I don't know what replacement actuator kit you got, but the one I installed came with a variety of hooks. Don't make the make mistake I did with a "U" shaped hook, it caused all of my problems and was really difficult to get apart. Use the "S" shaped one, I think the stock one is the same.
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
Electrical Are there any aftermarket door lock actuators that actually work?
  • 89notchDude
  • Nov 24, 2024
3K
Fox 5.0 Mustang Tech Dec 2, 2024
FastDriver
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
M
Too much for me to repair in my current housing situation
  • My Drama Magnet 04 Gt
  • Apr 1, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 14, 2026
Door doesn unlock with keyfob but locks fine
  • 05stang05
  • Jun 4, 2024
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 5, 2024
