Door lock help needed
  • Thread starter Thread starter 90blue5.0
  • Start date Start date Apr 30, 2010
9
90blue5.0
266
Regina, Canada
Apr 30, 2010
  • Apr 30, 2010
Ever since I replaced my heater core my drivers side door lock button will not work. The passenger side putton works to lock/unlock both doors but the drivers does nothing. I'm sure that all the connections are together. Does anyone have any suggestions? Does it make sense that one button works and the other doesn't, usually they go together right?
Cobra1741
152
  • Apr 30, 2010
so when u press the switch on the drivers door it wont move? but the passenger side will???
9
90blue5.0
266
Regina, Canada
May 1, 2010
  • May 1, 2010
That's right, the passenger door lock button works fine for both doors but the drivers side button does nothing - no lock or unlock.
MustangLX-5.0
856
Lehigh Acres Fla.
May 1, 2010
  • May 1, 2010
Take the switch out of the door. First remove the 2 screws that hold the switch panel in. Next, pull the switch panel out of the door armrest, and on the back of the switch panel, there are a couple more screws that secure the wiring. Remove those, then carefully unplug the back half of the switch panel so the pins slide out. Now that you got it out, spray something like QD electronic parts cleaner all over the terminals. Plug it back in, but dont attach the screws yet. Test the lock function now. If it still don't work, unplug again and spray cleaner underneath the switch rockers themselves. You want to get cleaner into the "clicking" switch contacts inside. Spray and push switch multiple times back and forth, spray again then repeat. Shake of excess cleaner and let sit a minute to dry. Plug back in and test.
If that still don't fix it, then either the switch went bad or there is a wiring problem. Do the power window switches work?
9
90blue5.0
266
Regina, Canada
May 3, 2010
  • May 3, 2010
Yes, the power window switches still work. I'll try cleaning the lock switch and go from there. Hopefully that's the problem.
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
1989 gt both doors wont lock or unlock help.
  • 1989 mustang gt
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 22, 2025
manicmechanic007
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
1989 Passenger side electric window issue
  • Sanchez_005150
  • Jul 17, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 4, 2025
WillWho?
W
