Door lock issue
  • Thread starter Thread starter newskool
  • Start date Start date Sep 26, 2010
newskool
251
37
48
Fayetteville, NC
Sep 26, 2010
  • Sep 26, 2010
My driver's side door lock is acting up. I just installed new solenoids about 6 months ago and i know they work. At first i thought it was an issue with my key, but after taking apart the door today i know it's not the key. All of my linkages seem to be hooked up properly so i don't think it's that either. It's almost like the hinge inside the door that moves with the key and lock solenoid is freezing up. I've sprayed a liberal amount of liquid wrench on it and it works until the first time i use the key to unlock the door. Any idea what the issue could be?
'88 5FOX
29
Seagrove NC
Sep 26, 2010
  • Sep 26, 2010
Is your lock cylinder worn, check to see if any of the linkages could possibly be bent. Also make sure you are getting proper voltage to the actuator. If that pertains to your problem. Just a thought.
newskool
251
37
48
Fayetteville, NC
Sep 26, 2010
  • Sep 26, 2010
actuator is brand new from LMR i can see it working it's something to do with the hinged part in the door that connects the linkage from the actuator/lock to the part that sticks up through the door.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 27, 2010
  • Sep 27, 2010
If you have not already done so, remove the inner door panel and watch the mechanism when you actuate the door lock switches. You will have to reconnect the switch wiring to make the actuator work. When you work the switch to move the actuator, you should see the binding in action. You may want to disconnect the actuator from the door lock mechanism and see if you can duplicate the problem.
newskool
251
37
48
Fayetteville, NC
Sep 28, 2010
  • Sep 28, 2010
Already done that. As far as i can tell it's not any connections on the linkage and i can see the actuator working, but it's not tripping the lever that connects between the actuator and the part that sticks out of the top of the door.
L
Lawbreaker5.0
543
Texas
Sep 28, 2010
  • Sep 28, 2010
Hopefully it's not what happen to me. I thought I had a problem and long story short the rod that goes up threw the metal frame in the door was getting hung up because I didn't have the piece that screws on that rod. I felt pretty stupid when I finally held the rod in the center of the opening while hitting the lock button or using the key and it worked instantly.
twistedwankel
200
Spring Hill, FL
Sep 28, 2010
  • Sep 28, 2010
newskool said:
My driver's side door lock is acting up. I just installed new solenoids about 6 months ago and i know they work. ... lock solenoid is freezing up. I've sprayed a liberal amount of liquid wrench on it and it works until the first time i use the key to unlock the door. Any idea what the issue could be?
I couldn't lock my DS door period when I got my car. The opener was jammed. When I removed the motor assy. the key worked perfectly, as did the button. When I got a new opener motor assy. it worked twice while testing (without installing the rivet which didn't come with it) then jammed creating the same issue.
I got my money back and left the DS door manual and the PSide electric. Not a big deal for me as don't have remote opener anyhow and always had to use a key to open doors. I seldom lock my convertible anyhow to save my top!!
I think most of those $20 Chinese multi fit replacements are crap. If I were to end up replacing mine I would get a quality OEM or do the clever last forever upgrade I saw on this board via Richter!!
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
Electrical 5.0 88 Foxbody Door Locks
  • 88VertFox
  • Aug 29, 2025
Fox 5.0 Mustang Tech Sep 2, 2025
Mustang5L5
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Electrical ’86 Mustang – Power Windows/Locks Dead After Terminator X Swap
  • 5.0 Mike
  • Aug 21, 2025
Fox 5.0 Mustang Tech Aug 21, 2025
5.0 Mike
