Door lock problem!?
  • Thread starter Thread starter TTMustang
  • Start date Start date Aug 5, 2004
T
TTMustang
  • Aug 5, 2004
hey, i have a '90 GT and the driver side door lock stopped working completely, and the pass. side would only unlock. i took both doors apart and on the driver side the switch wasn't getting any power so i jumped power(just to check) to it and checked it out with a test light and the switch worked, i then checked out the plugs going into the actuators and found that on both sides both the lock and unlock had power but when i plugged the new actuators in the drivers side nothing happened and the pass. side still only unlocked. this has been bugging me for months and final thought of goin online for help bc the dealers don't know anything, hope you can help me. Thanks
HISSIN50
34
129
Aug 5, 2004
  • Aug 5, 2004
they use reverse polarity switching, so make sure the grounds are good - there is one on each door, about dead center on the inner door skin.
there are large wiring connectors at the top of the driver side kick panel - i would check those to see what values you get.
good luck.
T
TTMustang
  • Aug 5, 2004
im gona check them out today at work... thanks for your input
PNY PWR
522
Wichita, KS
Aug 5, 2004
  • Aug 5, 2004
It's the actuators 99% of the time. I just replaced mine on my 90 and the locks work excellent now.
R
ratrapp
510
buena vista,va
Aug 5, 2004
  • Aug 5, 2004
somewhere between the door lock actuator and where the wires go into the body there probably is a broken wire,more than likely it's on the driver side as thats the most used door.this assuming the actuators are good and not locked up.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 5, 2004
  • Aug 5, 2004
Unplug the wiring connector to the actuators and use a test light across the two connections. If the light works both ways, then the actuators are bad.
Follow this link to fix your door lock actuator problems http://jrichker.stangnet.com/Mustang_tech/door_actuator_fix/1_of_8_door_actuator.htm
Stuck with door lock actuators that don't work and don't want to pay the $50+ for a new one? Tried the junkyard ones and found that they last six months and freeze up?
A new actuator for less than $4. Fix one side for $17, do both sides for only $23. I don't sell parts, I don’t make any money off of the upgrade, I just tell you how to do it cheaply and easily.
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
Electrical 5.0 88 Foxbody Door Locks
  • 88VertFox
  • Aug 29, 2025
Fox 5.0 Mustang Tech Sep 2, 2025
Mustang5L5
1989 gt both doors wont lock or unlock help.
  • 1989 mustang gt
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 22, 2025
manicmechanic007
J
89 mustang alarm install to lock and unlock
  • jk66
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 10, 2026
jk66
J
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
