door lock problems
  • Thread starter Thread starter jmd2914
  • Start date Start date Jan 3, 2006
J
jmd2914
937
Napa, California
Jan 3, 2006
  • Jan 3, 2006
alright whenver i hit the lock / unlock switch on the drivers side the passenger side door lock makes a grinding sound and wont lock or unlock but when i use the key on the outside the door locks and unlocks but is kind of hard to do. anyone know what could be causing this?
gt40_2003wes
I did sound a wee bit gay there.
Aug 14, 2005
461
ky
Jan 3, 2006
  • Jan 3, 2006
its the actuator startin to lock up it will eventually get to where it wont even lock with the key go ahead and take it out and then it will lock fine with the key.
W
wazazzle
618
In the dumpster behind McDonalds. WA
Jan 3, 2006
  • Jan 3, 2006
I had the same problem, but then after awhile the lock basically froze up. It wouldn't open up from the outside or inside--it was just stuck locked. It finally opened up several days later and I'd bet it is the lock actuator. Replace the the actuator.
HISSIN50
34
129
Jan 3, 2006
  • Jan 3, 2006
You can see Jrichker's article on how to swap in aftermarket actuators at a significantly lower cost than an OEM actuator. I did it and it works great.
Good luck.
J
jmd2914
937
Napa, California
Jan 3, 2006
  • Jan 3, 2006
i looked and i cant find the article, anyone got a link? and how hard is it to replace?
HISSIN50
34
129
Jan 4, 2006
  • Jan 4, 2006
Here is Jrichker's article.
Good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 4, 2006
  • Jan 4, 2006
Good luck.
Thanks for the referral. I really do need to fix that site, since some of the pages don't display. Try this one -
Follow this link to fix your door lock actuator problems http://jrichker.stangnet.com/Mustang_tech/door_actuator_fix/1_of_8_door_actuator.htm
Stuck with door lock actuators that don't work and don't want to pay the $50+ for a new one? Tried the junkyard ones and found that they last six months and freeze up?
A new actuator for less than $4. Fix one side for $17, do both sides for only $23. I don't sell parts, I don’t make any money off of the upgrade, I just tell you how to do it cheaply and easily.
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
1989 gt both doors wont lock or unlock help.
  • 1989 mustang gt
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 22, 2025
manicmechanic007
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
