door panels/handle interior question
  • Thread starter Thread starter Killerrobotjews
  • Start date Start date Apr 15, 2005
K
Killerrobotjews
62
  • Apr 15, 2005
Well my interior door handle doesnt work anymore, when i pull it it just clicks :/ I took off the handle covering, and the spring inside it looks really loose. How do i fix this?
Do i have to take off the door panels, and whats the easiest way to do this?
Thanks in advance!
gregpro50
140
Binghamton NY
Apr 15, 2005
  • Apr 15, 2005
You will need to pull the door panels. You can get a special tool to help you pull off the little plastic toothed things that hold it on but I have just used screwdrivers in the past to pry them off. There are little bars that run through the door and connect the lever to the latch mechanism. They have little plastic keepers that often break and will disconnect the bar. You will have to pull the panel off to find out though. Once you have it off the problem will be pretty obvious.
squeeeg
1,905
Michigan
Apr 15, 2005
  • Apr 15, 2005
You will need to take the panel off and see why it isn't working. It should be an easy thing to see. There is probably a clip that came off and a connector that came apart. If you need to replace that spring or the whole handle you have to have the panel off anyway.
K
Killerrobotjews
62
  • Apr 15, 2005
hmm, i'll go pull it apart now and see, where can i get those plastic keepers? (incase i need one)
gregpro50
140
Binghamton NY
Apr 15, 2005
  • Apr 15, 2005
The auto parts store usually has them. If not you can get them through 50resto or some place like that.
K
Killerrobotjews
62
  • Apr 15, 2005
alright, i got the sides and the bottom of the door panel seperated, but how do i get the top of it off?
gregpro50
140
Binghamton NY
Apr 15, 2005
  • Apr 15, 2005
You need to pull off the arm rest and then just pull out and up at the same time. Take the cover off the inside of the mirrors too and it will be easier. You have to pull the panel up to get it off the door.
K
Killerrobotjews
62
  • Apr 15, 2005
Thanks man, i'll go try it now
brb with the culprit lol
K
Killerrobotjews
62
  • Apr 15, 2005
Got the door panel off, thanks alot!.
Now to try and find the culprit... this is gonna be interesting, its hard to see in there!
K
Killerrobotjews
62
#10
  • Apr 15, 2005
  • #10
Alright, so i looked at it, and the first problem was that the plastic gears that were in the handle were off, thats what was creating the problem.
So i popped that back in, but now the handle doesnt pull back far enough to open the door, what could cause this? its almost as if the rod is too short!
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
P
Butchering up NICE 79 door panel yeah or neah
  • ponixpress
  • Jan 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 1, 2025
Bullitt347
