Door Speaker Grills
88-378
14
Alpharetta, GA
If any of you are replacing your speaker grills with new door panels I have a good tip.
First, the door panel has the holes already in you just have to poke the material out and align the dowels from the grill. I did this, put it on and the grill seems to keep popping off at the top.
so, I threaded the dowels with and M6X1.0 threader from my tap and dye kit and simply secured the speaker grill with a nut and washer and hit it with a little crazy glue so the bolt will not back out.
It works!
