door switch problem?
eagleone
Mustang 1990 GT…..door switch problem?
Drivers side door window switch works the drivers door window (up/down) but the passenger window (down only) & does not work either of the rear windows
Passenger door window switch only works the passenger window (up only)
Rear window switch for either side does not work (up/down)
Driver or passenger door lock switch does not work (lock/unlock)
The car has an after market alarm with a key fob that will lock & unlock both doors. A few seconds after the engine is started this alarm system will lock both doors. When the engine is turned off both doors unlock
From the info provided can this problem be solved?
