Door Window Adjustment.
  • Thread starter Thread starter PattyJoe
  • Start date Start date May 25, 2014
PattyJoe
  • May 25, 2014
Hello all. I recently picked up an 84 t-top with an 87-93 nose. I am having some difficulty trying to get the passenger window to go up and down on the tracks. I am assuming t-top mustangs use the same doors as convertibles since they do not have a frame around the window? Does anyone know any good articles or links on how to adjust the windows on a convertible or t-top fox or know what may be causing my windows to shift forward and aft causing problems going up and down.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
May 25, 2014
  • May 25, 2014
Sounds like the Guide Bushings are worn if it is flopping around, I just installed a new ps door glass in my car this week, its nice to have it go up and down smoothly.
PattyJoe
  • May 25, 2014
my window is not flopping in and out, it is going forward and aft like it isn't on a track at at all. I have to pull the window up and keep it level to get it all the way up. It's driving me insane.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
May 25, 2014
  • May 25, 2014
Bad Guide Bushings cause all that slop.
PattyJoe
  • May 26, 2014
I will have to give it a shot. Thanks for the suggestion!
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
May 26, 2014
  • May 26, 2014
You might wanna check the run channel weatherstrip too.
PattyJoe
  • May 27, 2014
It's a t-top car. I don't think I have a run channel. However after opening up the door that works perfectly I found the problem. Not only are the bushings missing off my passenger side door, but the top bracket(flat piece of metal held down with two bolts) that the bushing sits in is not there, allowing my glass to rock forward and back. So I need to find that bracket and order the bushings from latemodelrestoration. Thanks for all your help!
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
May 27, 2014
  • May 27, 2014
Glad to hear you figured out the problem.
Rear quarter window regulator
  • BADAZZOMBIE08
  • Mar 29, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 29, 2026
BADAZZOMBIE08
J
Windows won’t go up when car is running
  • Jraesims
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 15, 2025
Help! Problem with replacment window regulator motor
  • TTSaleen
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 24, 2025
General karthief
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
G
Intro and FB questions
  • gflat65
  • Nov 16, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
horse sence
