double clutching
  • Thread starter Thread starter 87foxstang
  • Start date Start date Sep 24, 2007
1 of 2 Next Last
87foxstang
Cromwell, CT
Sep 24, 2007
  • Sep 24, 2007
ok, ive heard of this a few times, not counting the fast and the furious
Ive even seen it mentioned a few times in the forums, what the hell is it exactly
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Sep 24, 2007
  • Sep 24, 2007
Here is the breakdown as I know it...
Double Clutching: Slowest of the shifting, was used long ago in big rigs more often than not. You start off in gear, when the time to shift comes, clutch in, pull the shifter into neutral, clutch out, clutch in, pull the shifter into gear. I guess this is used to help line the gear faces up in trannys without synchroes. Not something any new car needs, and not something used in racing.
Speed Shifting: Might even be as slow as double clutching. This is used when you have clutch issues more times than not. When the time comes to shift, you get to an even pedal pressure, not accelerating and not completely letting off. You slide the shifter out of gear without touching the clutch. Then put pressure on the next gear, and use the pedal pressure to bring the RPM easily yo the right spot (you just feel for it) and the shifter will slide into gear. Not used for racing, I have only used it for fun and when my clutch cable goes.
Regular Shifting: Used by most in normal driving and racing. With the car in gear, you push the clutch in, put the shifter smoothly into the next gear, and release the clutch. You do so by letting off the gas in between the shift, and rolling into the throttle for the next gear.
Powershifting: Used in racing only more or less. With the car in gear, get ready for the next gear with a little pressure on the shifter. When the right RPM hits, leave the gas to the floor and stab the clutch. Move the shifter (hence the pressure towards the next gear) as fast as possible, and have that clutch out before the RPMs scream to the limiter. When done right, the RPMs shouldn't climb much at all, the car shouldn't nose dive on the shift, and the timeslips should show it.
Thats about how I see it. I also prefer the last one, without it, I would probably have a mid 13 second car, .
87foxstang
Cromwell, CT
Sep 24, 2007
  • Sep 24, 2007
ohh so thats double clutching huh. Wierd if you ask me, why anyone would do that in a car like ours is beyond me. Thanks for clearing that up dude.
TRWXXA
190
RIGHT BEHIND YOU!!!... Made you look.
Sep 24, 2007
  • Sep 24, 2007
I don't think double-clutching has been required on cars since the 1920's.
Synchronizing gears have eliminated that need. If the synchros go bad, it's possible that you'd need to double-clutch to get the gears to mesh smoothly.
Double-clutching is accomplished by putting in the clutch, and moving the gear selector to neutral. Now you have to match the speed of the trannsmission's input shaft to the speed of the next gear you want to select. Release the clutch, and if you're up-shifting, let the engine RPM decrease to the RPM it'll be at in the next gear, put the clutch in, select the next gear, and release the clutch. If you're downshifting, rev the engine up to the speed that the lower gear will attain, put in the clutch, select the lower gear, and release.
It takes a lot of practice. If not done right, the loud grinding noise will tell you and everyone else around that you screwed it up.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Sep 24, 2007
  • Sep 24, 2007
I will stick to regular shifting! NO way would I powershift. I can just see something going wrong. That means I will have to spend $$$$ fixing instead of modding/gas in the tank/ insurance/car shows etc...
Flavadave4
1,044
21
49
Utica, NY
Sep 24, 2007
  • Sep 24, 2007
Double clutching is still used in comercial trucks.
My personal favorite is the "no lift shift"
Its the same thing as 25th's Powershifting!
87foxstang
Cromwell, CT
Sep 24, 2007
  • Sep 24, 2007
hahaha the "no lift shift", ive never heard it called that before, thats a good one
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Sep 24, 2007
  • Sep 24, 2007
No lift, power shift... either way its the same idea.
I have heard of people breaking them, but I have been powershifting for a solid 5 years on the same stock T5. Had it freshened up back in 03 I believe and never had an issue with it. Granted the same WAS true for my stock rear, and the ther day that went boom.
You gotta pay to play, and I can't stop powershifting now, so I am just prepared for the worst.
87foxstang
Cromwell, CT
Sep 24, 2007
  • Sep 24, 2007
wow i cant believe you've been powershifting for that long on a stock t-5, dayyyum.
88-378
14
Alpharetta, GA
Sep 24, 2007
#10
  • Sep 24, 2007
  • #10
Maybe he has a diesel under the hood with a heavy duty 12 speed!
skunk21
1,203
Taxachusetts
Sep 24, 2007
#11
  • Sep 24, 2007
  • #11
most states require you to double clutch to get your cdl. when I got my class a they wouldn't let you "float" the gears double clutching only. when I'm driving my truck I only use the clutch to start out then bring it up to the right rpms and drop it right into the next gear, down shifts I move into neutral blip the throttle to raise the rpms and drop into the lower gear.
LOL I have caught myself leaving work and upshifting my stang w/o the clutch, w/o even thinking, darn habbits.
ttop88
42
indiana
Sep 24, 2007
#12
  • Sep 24, 2007
  • #12
Double clutching went out with the advent of syncronizers. But I do think they have weekly classes over on the honda boards.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Sep 24, 2007
#13
  • Sep 24, 2007
  • #13
Yeah, funny thing is we had our 91 LX and now our 86 GT running low 12s on the same stock T5, and that just blew 3rd and 4th. I think it was from too many missed shifts though, my brother was learning on it, and missed a good amount of gears going down the track. getting rebuilt as we speak, and Saturday the car should go low 12s, maybe crack an 11 with me powershifting it .
87foxstang
Cromwell, CT
Sep 24, 2007
#14
  • Sep 24, 2007
  • #14
wow thats awesome...So are you going to LVD this saturday?
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Sep 24, 2007
#15
  • Sep 24, 2007
  • #15
a proper and crisp, fast powershift doesnt seem to hurt the tranny at all.
i powershifted the hell out of mine at the track last weekend, was doing it pretty good and it didnt hurt the tranny at all. before when i first stared doing it i was slow and it DID hurt the tranny i could feel and hear it, once you get good enough and fast enough it doesnt hurt it as much.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Sep 24, 2007
#16
  • Sep 24, 2007
  • #16
No Tasca Day at New England Dragway... Going to go up there and try to run with the H/C/I cars. Had one guy last year cheating big time. Went out and when everyone else was going 11.9-12.4 he ran a 10.xx @ 125. Needless to say when we cought on he ran a 12.x @ 109 (must have been spraying). Then in eliminations he tried spraying it again and missed 2nd and 3rd and lost with a mid 12 second pass. Glad the loser who tried blatently cheating lost in the first (maybe second) round, because he couldn't drive.
I am not sure if it hurts it or not, but a clutch will dictate how bad it is. A weak clutch will be easier on the tranny than a hard one.
87foxstang
Cromwell, CT
Sep 24, 2007
#17
  • Sep 24, 2007
  • #17
damn, thats pathetic trying to cheat like that, what a moron
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Sep 24, 2007
#18
  • Sep 24, 2007
  • #18
Yup and because I wasn't racing I went over and asked about the car, acting as the kid who didn't know. He told me full length headers and a cam about the same as a B cam. He was an arrogent prick, and next time I walked by I made a nice comment about nitrous not over coming a bad driver...
87foxstang
Cromwell, CT
Sep 24, 2007
#19
  • Sep 24, 2007
  • #19
haha way to go ...make sure he knows hes a ****ing prick
blackened88lx
Connecticut
Sep 24, 2007
#20
  • Sep 24, 2007
  • #20
Don't feel too comfortable. I felt the same way for a while. My stock t5 shifted smooth as silk, never grinded, and took every powershift without a complaint. Until one day I slammed it into 3rd and ended up with half the teeth missing. Most people would learn at this point, but powershifting is an addiction, and without it you might as well drive an automatic. I will powershift the **** out of my new $1100 gearset without mercy. It's just how a stick car should be driven.
1 of 2 Next Last
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
2003 Mustang gt. Clutch overheating.
  • 2003 mustang gt modded
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jan 5, 2026
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
new :poo: box, may need to hit you guys up for 79-82 info when i fix thIs turd.
  • rednotch
  • Sep 27, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2026
limp
