double flare questions
  • Thread starter Thread starter mustangdave
  • Start date Start date Dec 12, 2006
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Dec 12, 2006
  • Dec 12, 2006
What exactly is a double flare on a brake line, and how do you do it? Does stainless steel require special tools since it is harder than the usual stuff? I'm asking because I want to a custom brake system that pre-bent lines are not available for.
ultrastang
1,092
Arkansas
Dec 12, 2006
  • Dec 12, 2006
Try this link;
http://www.carcraft.com/howto/50919/index.html
www.ultrastang.com
thehueypilot
1,084
Medina,Tennessee
Dec 12, 2006
  • Dec 12, 2006
Good link above and I might add that SS is a lot harder to bend and flair unless you get it annealed (softened) and even then it is very hard to work with.
dolfan87
1,242
Lake Havasu, AZ
Dec 12, 2006
  • Dec 12, 2006
I bought an entire stainless line kit for my Mach 1, but wound up throwing every piece away. Not a single end sealed, and I had several flares professionally done.
I would stay away from Stainless unless you have someone doing the flares with a lot of experience.
M
mustangdave
2,976
North Carolina
Dec 12, 2006
  • Dec 12, 2006
Sounds like stainless is kinda hairy: are there any other options for a cool look on brake lines? Maybe an anodized look to regular mild steel?
M
mustangdave
2,976
North Carolina
Dec 12, 2006
  • Dec 12, 2006
I also don't see the "buttons" referred to in the Car Craft article in my search for flaring tools. I have a flaring tool and it has no such critter either. I have flared propane gas lines with no leaks but they were single flares on copper lines.
StaffAmerica74
120
Easton, Pa
Dec 12, 2006
  • Dec 12, 2006
You need to use the buttons when flaring brake lines... thats why its called a double flair. Autozone has the tool with the buttons for renting and when you are done you can take it back. I did the whole system on my mustang with no leaks. I used regular line though.
M
mustangdave
2,976
North Carolina
Dec 12, 2006
  • Dec 12, 2006
Thx. I saw it on the zoo's website. I would still like to try the stainless for corrosion resistance and looks. It looks like I need a heavier duty kit to flare it though. Eastwood has one but it is several hundred dollars!
66forfun
260
Pittsburgh
Dec 12, 2006
  • Dec 12, 2006
My tip is do not use a tubing cutter when trimming the lines to length, use a hacksaw.tubing cutters leave a beveled end on the tube and a double flare will be near impossible. also cutoff wheels shouldnt be used because of the end getting hot and is then harder to cold work, it could cause cracking in other words. good luck, rent a good flare tool and practice on scrap of the same matl.
DukeGnarley
597
Auburn/Ellensburg, Wa
Dec 12, 2006
#10
  • Dec 12, 2006
  • #10
I got a stainless brake line kit with my baers, and ended up having to modify them. i used a $12 ish tool from the local parts house and it ended up working, but it was a pain in the ass. i found that to ged the best results, i had to cut the line with a dremmel, then use a lot of sand paper to get the end perfectly smooth. only problem with this is that it leaves a lot of metal dust in the lines that you have to get out.
ultrastang
1,092
Arkansas
Dec 12, 2006
#11
  • Dec 12, 2006
  • #11
This is the double flare button the guy is holding (from the article).
http://carcraft.com/howto/p116197_image_large.jpg
This makes the "first stage" of the double flare.
thehueypilot
1,084
Medina,Tennessee
Dec 12, 2006
#12
  • Dec 12, 2006
  • #12
Try this link for steel brake lines that come in different colors for something different. http://store.summitracing.com/egnse...4294924496+115&Nao=10&Ntk=KeywordSearch#rstop
BB1966
297
Beaufort , NC USA!!!!
Dec 12, 2006
#13
  • Dec 12, 2006
  • #13
I made my lines with a roll of strainless. I used a tubing cutter but I had to file the end smooth to keep it from splitting. Most of my flares are inverted ( the taper comes out not in) and they were a pain. It does take extra effort to make them in stainless but in my .02 it is worth it. 80% of my lines are hidden anyway and the adjustable prop valve is inside by the driver seat.
pabear89
2,126
High in the Hills of So Ca with the Voices in My H
Dec 12, 2006
#14
  • Dec 12, 2006
  • #14
Use a sharp tubing cutter, then flat file the end to remove the cutting taper.
With a 37* tubing flare tool make your flare with enough pressure to form an equal ring of tubing showing around from the the wedge.
Works better than a double flare, but you only can use it once.
unlike a double flare that rolls the end in so it makes a crush seal when you tighten it down.
Depends how hard you tightened it prev is to how much crush area is left to reseal.
PB
M
mustangdave
2,976
North Carolina
Dec 13, 2006
#15
  • Dec 13, 2006
  • #15
Great advice everyone!!! I also like the look of the colored hard lines from Summit! Decisions, decisions.
ozstang65
313
Queensland, Australia
Dec 14, 2006
#16
  • Dec 14, 2006
  • #16
Rothenberger ROFLARE is an absolute gem of a tool. Get the double flare adaptor and their pipecutter and you are set. The 'double rail' tools are a PITA. Once you've used one of these you'll never want to use anything else for flaring ever again.
Sponsored New J&M Release: 2024+ S650 Full Front + Rear Stainless Steel Braided Brake Lines
  • MRaburn
  • Mar 6, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Mar 6, 2026
MRaburn
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
