dowel pins purpose?
I was wondering how inportant the head dowel pins are to assembling an engine and what could happen if you do not install them. I know they help align the heads, but just wondering the effects of the heads not being aligned right i suppose.
Thanks!
The head bolts (or studs if you use them) do not precisely align the heads, so the dowels are needed. You need a precise alignment so your lower intake manifold will seal up properly without warping or leaking. You also may have problems with piston-to-valve clearance. The tolerances on these things are measured in thousandths of an inch, so you want to make absolutely sure that the heads are exactly where they are supposed to be.
what he said...
they have a ground surface which can be held into the +/- .xxx MM range...
You could easily do a lot of damage to an engine without the dowels installed. Coolant passages might not line up correctly, fire rings on the cylinders may not seal, the heads could potentially move around under load. It could definitely let coolant and oil mix, or let coolant into the combustion chamber.
