Drag race suspension?
What is out there that will help my 60' time? Right now i run a 1.8 60' and i use micky thompson ET streets, traction bars and am wondering what i can do to the suspension to make me launch better. if you have any sugestions please let me know?
This is a roller front end ( roller upper/lower arms and spring perches) I built for a drag racing '68 big block coup. The owner said the car ran 3/10's quicker, it would hook a lot harder and pull the front tires another 6-8" at the starting line.
Getting the front end to move quicker will help a lot.
John
I'm not a drag racer but I like this idea for a leaf spring. This could be done at home with a stock set of leafs and a used set as a donor for the extra leafs. I count 6 on the front side and 3 out back. All 6 go under the housing. This should stop the wheel hop and keep the squat factor under control.
The roller UCA's are $550
The roller LCA's are $329
The roller perches are $199
10% off on the whole kit.
John
www.opentrackerracingproducts.com
