draining radiator
  • Thread starter Thread starter v850mustangluvr
  • Start date Start date Nov 29, 2004
V
v850mustangluvr
71
Texas
Nov 29, 2004
  • Nov 29, 2004
wheres the bolt to drain my coolant from my radiator
ive looked at the bottom of the radiator buy i dont SEE ANY drain bolt
need help asap!!!!!!!!!
V
v850mustangluvr
71
Texas
Nov 29, 2004
  • Nov 29, 2004
ive read it on the pass side, well its NOT, ive also read follow the bottom radiator tube and its supposed to be on the pass side, WELL MY LOWER RADIATOR HOSE IS ON THE DRIVERS SIDE!!!!!!! i dont see ANY drain bolt, can i just undo the top radiator hose and let it come out that way?????
V
v850mustangluvr
71
Texas
Nov 29, 2004
  • Nov 29, 2004
ive just looked again to make sure i dont sound like an idiot, but theres no wing nut or any type of bolt on the passenger OR drivers side, I dont know if its a stock radiator or not??? whats going on, shi* im about to just take it to jiffy lube!!! i would rather do it myself buy i just dont get where the drain plug is!!????????? theres only 2 screws on the bottom of my radiator one on each side, but there nothing to unblot, its just the tip of the screw and all i see is threads???? its coming from the inside of the radiator out, anyway im lost, any help would be appreciated!!!!!! thanks!!!!!!!!!!!!!!!!!!
V
v850mustangluvr
71
Texas
Nov 29, 2004
  • Nov 29, 2004
ok those screws i was talking about are just the bottom radiator mounts.......IM LOST????????????????
94gsl5.0
223
seatown
Nov 29, 2004
  • Nov 29, 2004
I just pull the bottom rad hose off when draining my rad.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 29, 2004
  • Nov 29, 2004
Can you post a picture of you radiator?
The stock radiator has that wingnut on the passenger side about halfway down the radiator and you just loosen it up and it will start draining the more you loosen it up...
I know with my Griffin Radiator I don't have a drain plug so I just undo the bottom radiator hose and it all comes pouring out...
D
dude5l
201
Grande Prairie, Alberta , Canada
Nov 29, 2004
  • Nov 29, 2004
I just use a shop vac and suck it out...a lot less messy!
The Shape
2,224
East ARKANSAS Delta
Nov 29, 2004
  • Nov 29, 2004
My radiator has the drain, but I still just pull the bottom hose loose to drain it.
HISSIN50
34
129
Nov 29, 2004
  • Nov 29, 2004
huh?
even with the removal of the petcock, i like to drop the lower hose - much quicker and easier draining while flushing (if you let the petcock be the sole drain, you will be flushing all day long).
good luck.
Black1987Stang
1,422
Jersey Shore
Nov 30, 2004
#10
  • Nov 30, 2004
  • #10
Those 2 screws should be the automatic tranny cooler lines. and whether if u have a petcock or not just use lower radiator hose, its easier, faster, and gets more of the coolant out. The upper radiator hose would barely do anythin
D
dude5l
201
Nov 30, 2004
#11
  • Nov 30, 2004
  • #11
HISSIN50 said:
huh?
I just attatch a long thin hose to the wet/dry shop vac, feed it to the bottom of the rad and suck the a/f out...no mess.
V
v850mustangluvr
71
Texas
Nov 30, 2004
#12
  • Nov 30, 2004
  • #12
wtf!!!!!!!!!!!!!!! I got the thermo housing off using a 1/4" socket and small ratchet and didnt have to move the dizzy at all....and put a new thermo and now that im trying to put the damn thing back in I cant get the bottom bolt back in!!!! WTF!!!!!
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 30, 2004
#13
  • Nov 30, 2004
  • #13
Just use a combination of swivels and extensions to help with that lower bolt...it is a bit of a pain to get to...
HISSIN50
34
129
Nov 30, 2004
#14
  • Nov 30, 2004
  • #14
as 5sp said, they can be a bit of a pain to get back in. i like to use those ratcheting box end wrenches. an allen head bolt would be much easier to install.
Engine Radiator with no shroud provision... What to do?
  • FastDriver
  • Apr 22, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
FastDriver
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
Block draining
  • JD1964
  • Mar 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 27, 2026
JD1964
Oil cooler delete 4v 4.6 1999 cobra mustang
  • sami12
  • Feb 24, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 25, 2026
GOvert
G
Engine 1986 GT Overheating issues
  • 86 5O GT
  • Jan 25, 2026
Fox 5.0 Mustang Tech Jan 29, 2026
86 5O GT
