Engine Dreaded 5v reference
So you have 5V on the tan wire when you backprobe? What about when you front probe by unplugging the sensor with key on? Are you able to get 5V from the physical connector that contacts the MAF pins?
You can also test at pin 50 on the ECU which is your signal return. Pin 9 is your 5V reference.
When i backprobe with mass unplugged i get 5v. Soon as plug in none
