Drive Better?
  • Thread starter Thread starter justin82
  • Start date Start date Oct 4, 2017
justin82
334
17
48
Oct 4, 2017
  • Oct 4, 2017
I've been going on little drives after work....just to take my mind off things....is it me or does the car seem to drive better once it gets warmed up?
thanks
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Oct 4, 2017
  • Oct 4, 2017
I notice no difference really with mine. Might want to check codes to see if there is anything stored
justin82
334
17
48
Oct 4, 2017
  • Oct 4, 2017
what would checking the codes say?
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Oct 4, 2017
  • Oct 4, 2017
if there is anything wrong with the motor, sensors, relays, and other components
JD1964
there is enough sticking out to grab on to
3,587
1,607
194
Maryland
Oct 4, 2017
  • Oct 4, 2017
Before normal operating is reached the system is in open loop where fuel control is fixed by the tables programmed in the ecu. Normally, when the engine reaches operating temperature the ecu switches to closed loop. In closed loop the ecu takes measurements from the O2 sensors to manage fuel mixture.
It's possible you notice it running better once warmed up since closed loop comes into play.
justin82
334
17
48
Oct 4, 2017
  • Oct 4, 2017
gotcha!
stykthyn
5,232
2,652
223
gainesville
Oct 5, 2017
  • Oct 5, 2017
Mine is a smelly beast no matter what the engine temperature is.
88LXSleeper
146
56
48
Oct 5, 2017
  • Oct 5, 2017
Are your cats gone? I think that is why mine stinks.
stykthyn
5,232
2,652
223
gainesville
Oct 5, 2017
  • Oct 5, 2017
Yeah. I
yeah. I'm putting new ones in when I redo the exhaust.
General karthief
Mod Dude
Aug 25, 2016
28,109
10,723
213
polk county florida
Oct 5, 2017
#10
  • Oct 5, 2017
  • #10
Whats this stinking thing ya'll are going on about?
89 gt no cats, no stink
Had a 92 convertible no cats no stink, this one still had the air pump too, gt air pump long gone.
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Oct 5, 2017
#11
  • Oct 5, 2017
  • #11
I just kept my cats. I live in a nanny state anyway. It's "for the children"
Reactions: 95BlueStallion and General karthief
JD1964
3,587
1,607
194
Maryland
Oct 5, 2017
#12
  • Oct 5, 2017
  • #12
Been over this before but here goes again. What Tstat are you all running? Anyone running a stat cooler than the factory spec 192 degree may not even be entering closed loop
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Oct 5, 2017
#13
  • Oct 5, 2017
  • #13
I've read on some reputable sources that the fox ECU enters closed loop around 140-150 degrees.
JD1964
3,587
1,607
194
Maryland
Oct 5, 2017
#14
  • Oct 5, 2017
  • #14
I had heard otherwise.
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Oct 5, 2017
#15
  • Oct 5, 2017
  • #15
I'm not 100% sure
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Oct 5, 2017
#16
  • Oct 5, 2017
  • #16
170 degrees is what I recall
JD1964
3,587
1,607
194
Maryland
Oct 5, 2017
#17
  • Oct 5, 2017
  • #17
I wonder why the stock Motorcraft thermostat is a 192. Did they just pick that number randomly? It seems random, doesn’t it!? Those engineers, they mess with your brain every time.
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
H
Hesitation & sputtering
  • healy1963
  • Apr 16, 2026
2005 - 2014 S-197 Mustang -General/Talk- Apr 16, 2026
healy1963
H
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
