Fox Drive line vibration at specific speed
To cure mine I:
– Balanced my wheels/tires & set my alignment
– Checked my suspension bushings, transmission cross-member bushings, the trans mount, and engine mounts
– replaced front & rear u-joints
– set pinion angle parallel parallel to the transmission/engine
– replaced axle bearings
– ensured my pinion flange nut wasn’t loose
- took D/S to transmissions shop. Balance was fine, but D/S was not true. They used a heating and cooling technique to true it. However, they could only get it to .008" & there is still a noticeable vibration. This is/was one of the factors that eventually drove me to swap in a T56 which will end up replacing trans, both yokes, both U-joins, and the driveshaft. *fingers are crossed*
Putting it on a lift and running the drivetrain is a technique I've used... I've even crawled under the car a bit before deciding that doing so just wasn't worth the risk of some garment getting caught up in a rotating part and getting myself mangled. Plus, when the suspension is unloaded all of the angles change and bushings are unloaded. So, while it might work, it might not reveal anything.
Reactions: General karthief
I fought a cyclic vibration like a washing machine on my T-Bird for a couple of years. Did just about everything I could to get rid of it. Dynamic wheel balancing, rebuilt the rear end and even changed the gears, got the steel DS balanced, had a custom aluminum DS built, sold the Lakewood bell housing and installed a SROD bell housing, tore the TKO down and checked the main shaft for runout, replaced the tail housing bushing, etc.
Finally got ahold of Joe Dederichs of Dederichs Motorsports and walked him through everything I did and he asked if I had checked the input shaft runout on the TKO…nope. Was waaay out and took two shim packs to get the right combination to get the end play down to 0.00” with the input shaft bearing retainer installed with no sealer. Reinstalled and vibration was gone.
After all that BS I was so glad to have it fixed as I was ready to blow the car up.
Well all I can tell you is that is what solved my vibration and I chased it for two years. Good luck and I hope you find it as it was absolutely one of the most frustrating things I’ve had to deal with car wise.
Reactions: limp
Maybe you're more adept, but the only thing I saw at the pinion was that the seal was leaking. The end play did not seem bad to me, but I didn't have any special tools I was using to measure or anything.
I would expect that you could eliminate the clutch, & input side of the trans by going into neutral, letting the clutch pedal up, and shutting the car off on the highway. If the vibration disappears, then you've narrowed the vibration to the front end of the drivetrain. If it doesn't, then you've eliminated the front end from the list of culprits, assuming of course that you only have 1 vibration source.
Fellas I might have a huge revelation for everyone dealing with a mystery vibration, make sure your rims are ACTUALLY centered. Stock rims are lug centric so the bulge on the acorn lug nut centers the rim as it tightens. So hold it in place and hand tighten the lugs while keeping the rim centered with the hub then tighten correctly in stages in a star pattern. I haven’t found any hub centric rings that would fit the stock rims but maybe we can get them custom made but just doing this helped tremendously with my 60-70 mph vibration. Hope this helps!
